Results 1 to 5 of 5
Thread: sr 50 r cold start problem
    Oct 2017
    Skopje, Macedonia
    Hey guys,
    there is a problem with my sr 50 r 2016
    First cold start is awful. I dont know how to describe. 10 minutes on the ignition button. it wont start. Like there is no gas coming in the carburteur. And when it starts after 10 - 15 minutes if you dont start driving it will cut off. What seems to be a problem?
    ontario
    its maybe a dirty idle jet. if you have no luck with that try the third or fourth needle clip setting. if still no luck then i would get a brand new sparkplug in case yours is bad. if nothing works report back and get ready to get your hands dirty
    Oct 2017
    Skopje, Macedonia
    Thanks for the advices. I will try everthing you said.
    Dec 2015
    Cambridge, MA
    i second the carb cleaning recommendation....i'd put my money on a clogged pilot jet
    2003 Vespa ET2 50cc
    2001 Triumph TT600
    1993 Yamaha Razz 50cc
    Oct 2017
    Skopje, Macedonia
    Hey guys, guess what.....i found time this weekend for the scooter. The problem was broken spark plug. I've change it and it starts like new. So happy that wasn't a big deal. Anyway, thanks for the advices.
  1. Cold Starting Problems on a Mojito 50
    By bishop637 in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 03-15-2016, 10:37 AM
  2. 2003 ditech 50 cold start problem
    By keybeater in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 10-10-2013, 09:36 PM
  3. SR 50 R Factory Starting Problems! Please HELP!
    By core in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 01-01-2010, 01:21 PM
  4. Cold Starting Problem Solved
    By TiminIndy in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 03-21-2004, 07:33 PM
  5. SR 50 in cold weather, and Q about pipes
    By Justskipee in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 12-19-2003, 05:06 PM
