Page 1 of 4 123 ... LastLast
Results 1 to 15 of 57
Thread: What did you do with your TUONO today?
    Aug 2010
    Chojnice POLAND
    This thread is missing.. So. I bought Voltmeter. I try to locate it somewere close to speedo. Also I want to change my regulator to Honda NC700 thing. Witer is coming. Cold outside. What can I do with T to make it better?
    Also I must change my chain and sprockets. Now I have 15x40. I want bigger front sprocket so I will go to 16x45. Front wheel should go up easly on 2nd gear..
    apriliaforum expert ghedunk's Avatar
    Nov 2005
    NJ
    I have installed one of that same voltmeter on 5 of my bikes . They are great .
    04 Tuono
    09 Husqvarna SM610IE
    84 R100RS
    83 R100RT
    08 Concours14
    12 Tuono V4 a-PRC
    apriliaforum expert spencer's Avatar
    Aug 2004
    New Oxford, PA
    purchased where?
    Oh, BTW I put a tender on mine....
    2004 Tuono
    Jun 2016
    North Yorkshire, England.
    Stripped down for a good clean, wheels away to be painted, exhaust away to be ceramic coated satin black, front cam cover gasket to replace, swing arm and dog bone off for bearing check / re grease.
    Forks need lowers re painting too.
    Aug 2010
    Chojnice POLAND
    Aliexpress.. 2 dolars delivered to Poland.
    Wysłane z mojego D2303 przy użyciu Tapatalka
    apriliaforum Member BMW851's Avatar
    Feb 2013
    Blue Mountains, Australia
    Put it back together after replacing front cam cover gasket, fast Idle assy. and cable, cleaned and re-oiled BMC airfilter, fixed a host of niggly age related bits and pieces that had perished, replaced a split coolant header tank, cleaned up the throttle body, replaced the odd 4mm allen head dome bolt, particularly this one which the PO had snapped an allen key off in inside the airbox, changed the oil and filter, adjusted the new chain, raised the forks in the triples.
    All right it's been off the road for a week and a bit waiting on parts, but was fun to get it back together yesterday and today, then out for a road test ride around the block which became a 1/2 hour ride, nothing came loose which is always a good thing and no more oil leaks.
ID:	345896Click image for larger version.
Name:	Ready for next bit.jpg
ID:	345898Click image for larger version.
    Not to shabby inside for an engine that's covered just under 64K and one would say hard Km's with the 2 PO's.
    So long and thanks for all the fish
    Nov 2005
    NJ
    Found voltmeter amazon . They are dirt cheap . They have 4 colors . And they are potted . There are also round ones that you just drill a hole and it pops in . Just look around not hard to find .
    04 Tuono
    84 R100RS
    83 R100RT
    08 Concours14
    12 Tuono V4 a-PRC
    apriliaforum Junkie Ario's Avatar
    Poland
    Quote Originally Posted by stuntmachine View Post
    Where do you plan to connect it? To the relay?
    EDIT
    1. Bought the voltmeter (yesterday) - to be installed
    2. Ducati 1098 rear brake pump installed (last week)
    3. New rear tire (Metzeler Z8) - hope it's better than Dunlop Qualifier which is IMO sh*t
    Aug 2010
    Chojnice POLAND
    Quote Originally Posted by Ario View Post
    EDIT
    + somewere on ignition cable. I dont know yet. Also I will check the valves over the winter..
    Aug 2010
    Chojnice POLAND
    Snow outside so I remove all fairings to give them good clean. I found massive oil leak from cylinder head cover. I saw it before but it was small. I need a new gasket... Mayby somebody check the valves before and that`s why it leak from there.
ID:	347765Click image for larger version.
ID:	347766Click image for larger version.
ID:	347767Click image for larger version.
    Aug 2005
    Perth W/Australia
    They often leak from there. New gasket should fix it.
    Tuono Racing + KTM 990 Adventure =
    apriliaforum expert VFR4Lee's Avatar
    Sep 2008
    Sitting on a park bench. Eyeing little girls with bad intent. Channeling Jethro Tull.
    Italian tune up and a first attempt soundtrack.
    Beast in the tunnel. Revving and grinning.
    My Tuono suits me to a "T".
    Thunder!
    Aug 2010
    Chojnice POLAND
    Will 110link chain fit 16x45 gearing?
    apriliaforum expert BigGlen's Avatar
    New Rochelle, NY USA
    And THIS is what your clutch fluid should look like on your Gen One!
    2003 Tuono: Leo Vince slip-on, Factory Pro Chip, custom mapped Power Commander III, HiFlo AFE air filter, '00 snorkle, Forged Alum-Marchesini Wheels, Ohlins Shock, GP Suspension internal Showas, EVO Fuel Pres Modifyer, 525-16/43 final drive (after I wore out the 520), TCM low rear sets, Scorpion Lithium Battery, Pirelli Angel GT's.
    Aug 2010
    Chojnice POLAND
    Quote Originally Posted by BigGlen View Post
    In first few days alter change...
  1. What did you do on your Shiver OR Dorsoduro today ??
    By mh_dorso750 in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: Today, 09:22 PM
  2. What did you do to your Caponord today..!!!!
    By BigSteve in forum ETV1000 CapoNord (2001-2007)
    Last Post: 04-14-2018, 05:38 PM
  3. What did you do with your Falco today?
    By AJJohnson in forum SL1000 Falco Forum (all years)
    Last Post: 03-25-2018, 01:31 AM
  4. What did you do to your Mana today ?
    By burningmay in forum 2008-2014 Mana 850 and Mana 850 GT-ABS
    Last Post: 03-16-2015, 11:53 AM
  5. What did you do to your bike today?
    By Sign Guy in forum RST1000 Futura (all years)
    Last Post: 03-21-2012, 10:37 PM
