Results 1 to 9 of 9
Thread: Tank decals removable?
    apriliaforum prov-nov mrk_d's Avatar
    Sep 2013
    Santa Barbara, CA
    My Tuono has an earlier steel Mille tank, and I'd like to purchase a stock plastic tank, seal it, and replace the metal tank at some point. I want a plain black tank, but the tanks I've stumbled across have the red Nero paint job R sticker on them. Is this sticker easily removed? I've asked multiple eBay sellers but none have replied. Thanks!
Name:	Screen Shot 2017-11-05 at 1.16.14 PM.jpg
    Aug 2010
    Chojnice POLAND
    No. Its under the clearcoat
    Wysłane z mojego HTC Desire 320 przy użyciu Tapatalka
    Sep 2013
    Santa Barbara, CA
    Quote Originally Posted by stuntmachine View Post
    That's what I feared...thanks for confirming!
    Jun 2016
    North Yorkshire, England.
    Yes,they can be removed, I've done it and replaced them because they were lifting in places slightly.
    However, as said, they are lacquered. I ended up with a line where the lacquer met the removed decal.
    I used aircraft transparency polishing clothes from Micromesh to polish this line out.
    I then fitted new decals in the originals place. Not perfect but damn near.
    If you intend to remove the decals leaving the tank bare, you'll need to blend in this lacquer line then get the tank re lacquered...not impossible by any means.
    Feb 2016
    Isle of man
    Quote Originally Posted by mrk_d View Post
    Hi mrk_d
    Just wondered why you would change your tank from a steal 1 to plastic?
    The poly tanks are prone to swelling I have currently 3 poly tanks and all have swollen i was thinking of getting a metal tank to stop this but having the racing tuono it really needs to be a poly tank.
    It may just be our really poor fuel mix with ethanol over in the UK not sure if you have the same problem in the states..
    Aprilia rsvr
    Tuono Racing number 088
    Sep 2013
    Santa Barbara, CA
    Quote Originally Posted by Stevex View Post
    Excellent -- thanks! Good to know I may be able to tackle this without a base coat spray involved.
    Quote Originally Posted by Iomtuonoracing View Post
    Hi mrk_d
    My gas light doesn't work with the metal tank which is a bit irritating, and I want to return the tank to stock partly because it looks better (the Mille tank should have side shrouds, which I don't have, nor do I want to buy). I plan to completely seal the plastic tank before installing to hopefully mitigate swelling, but I'll probably hang onto the steel tank just in case. I think the plastic tank is a touch lighter too but I could be wrong on that front.
    Feb 2016
    Isle of man
    I see I have heard of sealing the tank never thought of doing it though. I just put 1 of mine in the loft as it's really warm
    Aprilia rsvr
    apriliaforum Junkie mwlehman's Avatar
    Apr 2013
    what were you going to seal plastic tank with? just curious...
    Sep 2013
    Santa Barbara, CA
    Quote Originally Posted by mwlehman View Post
    Caswell epoxy tank sealer. I've read generally good reviews, especially if care is taken during prep and application.
  1. bad experience with decal removal
    By MikkeMille in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-10-2005, 05:37 AM
  2. Old Tank Pad Removal
    By IK_25 in forum RS125 Euro-archive
    Last Post: 06-27-2005, 06:48 PM
  3. Need new tank decals
    By Devilman in forum RS125 Euro-archive
    Last Post: 08-06-2004, 11:17 PM
  4. Sticker/Decal Removal Technique's
    By GhostDog in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 10-08-2003, 07:41 PM
  5. Tank Decal
    By RSVRJIM in forum Aprilia Owner's Pictures, Videos, and Sounds
    Last Post: 04-30-2003, 08:46 PM
