Results 1 to 15 of 15
Thread: sprocket gearing
    Feb 2012
    Portland OR
    sprocket gearing
    I know this has been discussed before, but what's the opinion of sprocket sizes? I currently have 15/41 and thinking of going up a tooth on the back for better acceleration. Since the stock front is 16, does dropping a tooth cause premature wear on the chain guides?
    apriliaforum Junkie dfoustou's Avatar
    Aug 2014
    silver spring
    yes, it might wear the chain guide. I don't know for sure though. I am using 16 and 17.
    Dionysis
    79 CX500C
    07 RSV1000R
    08 WR250R
    IBA#58777
    apriliaforum expert steelman_2's Avatar
    Sep 2012
    Finland
    The stock gearing is 16/40 and the most cheap upgrade ( and mostly done) to make bike more agressive is 15/42 gearing, I do not like go down with front ( wear / the angle speed of the front sprocket rises) so I've gone with 16/44 ( which is almost the same than 15/42) , then you need also 2 link more on your chain.
    I'm a (triathlo)nist, that's why I've joined A(prilia) & A(udi) club.
    Jun 2006
    Columbus, GA
    I was always good with 16-42 on these bikes. I ride the road a lot so a 15-41 or 42 would be too aggressive for me.
    2007 Tuono 1000R Factory
    Cored OE Racing CansMap2Pazzo Knock-offs15-40AF1 Link PlatesAprilia Sliders
    ProTaper Mini-LowClear Signal Lenses
    Retired - DJ, Turntablist, Creator and Mixologist.
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
    Aug 2014
    silver spring
    I like the 16/42 for street riding as well.
    Dionysis
    79 CX500C
    07 RSV1000R
    08 WR250R
    IBA#58777
    Feb 2012
    Portland OR
    After some thought, I went w/ 15/42 which seems to give a bit more acceleration, though it will probably wear the chain follower faster. The new chain and sprockets are noticeably smoother- next is to test the rear wheel alignment- any tips on that technique?
    Aug 2014
    silver spring
    i just measure the position of the rear wheel axle very carefully.
    other options: https://www.youtube.com/watch?v=uDmn-zngFRY
    Dionysis
    79 CX500C
    07 RSV1000R
    08 WR250R
    IBA#58777
    37 miles E. of ATX, TX USA.
    I prefer 16:44 as it seems easiest on the chain guides, they were never really an issue on the Gen1 chassis but on Gen2 chassis they definitely are.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Feb 2012
    Portland OR
    Thanks for sending that- when I removed the old sprockets, I could see uneven wear on the sides of the rear sprocket ( the inner side was worn more than the outer side), indicating that the rear wheel wasn't aligned properly
    Quote Originally Posted by dfoustou View Post
    Nov 2011
    sth oz
    Quote Originally Posted by TeddyG View Post
    Make sure your front sprocket orientation is correct - the collar faces inwards on our bikes
    apriliaforum expert CorseKiwi's Avatar
    Mar 2011
    New Zealand
    Now that I have test ridden with Sefano's twin velocity stacks, open airbox and bazzaz tuning I think I will change from 15/42 to 16/42. The acceleration is noticeably improved!!
    07 RSV 1000 Factory
    03 Ducati ST4s ABS, Lots of mods
    Previous
    05 Ducati 999S,07 Tuono 1000 R, 03 Tuono Racing, 06 Triumph 1050 Speed triple
    Feb 2012
    Portland OR
    Thanks- I made a note of that while rwemoving the old sprocket, along with getting new thrust washers. I was surprised the torque setting is only 37 lbs, but another member posted about shearing it off using too much force
    Quote Originally Posted by jess67 View Post
    apriliaforum Junkie mwlehman's Avatar
    Apr 2013
    it the last 3 week I have gone from a 15/44 to 17/44 to 17/42 to 16/42.... just messing around seeing if gearing and sedated riding style had much affect on gas mileage...not much
    15/44 seemed like I was constantly shifting, 17/42 was just a little to high for around town...leaving 16/42 in for now...my wife has 16/44 on her tuono but I doubt she knows or cares
    Jul 2014
    Earth
    been using 16/42 for almost 2 years and a half.. really love it.. even in town or long travel.. but on the next change will gonna try 16/43 combo.. will see how it goes
    Nov 2011
    sth oz
    Quote Originally Posted by CorseKiwi View Post
    1 tooth on the front sprocket would have to be worth at least 10hp, thats a fair gain.
  1. RXV motard sprocket gearing
    By soyrico in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 07-02-2008, 07:14 AM
  2. sprockets/gearing
    By nopainnogain in forum RS50 Technical
    Last Post: 10-28-2007, 09:18 PM
  3. Stock sprocket gearing? 16/42?
    By Jglisso in forum SL1000 Falco Forum (all years)
    Last Post: 06-24-2006, 08:23 PM
  4. Sprocket gearing combinations
    By HarmanKardon in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 11-30-2005, 12:29 PM
  5. Sprocket Gearing
    By Floyde in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 01-27-2005, 05:06 PM
