Results 16 to 27 of 27
Thread: How easy is it to push-start a Futura?
    Sep 2004
    Sweden, Linköping
    I had to do I once when my RR died. Found a small hill steep enough. Dont remember the gear I selected.
    Mods: Modified Öhlins fork from mille R, EBC brake discs, HEL front brakelines, Carbon RS 250 front fender, Wiring mod for charging. Engine related:05 map, Iridium plugs, tuneboy, derestriced intake, old mille airboot, staintunes exhaust. Lambda bung hardbrazed in the "breadbox". Öhlins mille R rear shock with 110N/mm spring and the integrated hydraulic preload adjuster. LED Voltmeter installed inside the dash for monitoring charging. Duc 999 radial m/c for brake and clutch. EBC 320mm brake discs
    CBR 600 -07 MOSFET R&R FH008EE providing stable 14.4 - 14.5 V (with my wiring mod). Daytona heated grips with mccoi pwm controller and automatic chain oiler
    apriliaforum expert rblue02's Avatar
    Blueridge GA, USA
    Was successful once with 2 or 3 pushers on a slight downhill, in 3rd gear.
    Regulator was bad, so the bike later stopped running on my return home, due to low voltage.
    Recommend confirming nominal on-bike charging before riding again.
    '02 Futura, Blue
    90k miles and all is well.
    apriliaforum expert haga lout's Avatar
    Jun 2009
    oldham uk and soon gibraltar
    I carry a jumper pack in the top box the new ones are small now
    apriliaforum expert photoRotor's Avatar
    Mar 2012
    SE corner of the NW
    Did it once after the OEM R/R died. Had a friend, and a small shallow hill, and used 3rd gear IIRC. Was like pushing an elephant.
    JD
    '01 Futura
    apriliaforum expert flying fox's Avatar
    Apr 2008
    Stockton-on-Tees,UK
    I used a big hill and freewheeled in third to 25mph - started no problem
    Tried bump starting down a small incline and being pushed - got nowhere.
    04 Silver,FPR Mod,Derestrict Airbox,Mille Boot,Reg/Rec Mod.,05 Map,Heated Grips,Smoked Screen,Beftura Forks,Scottoiler,Stone Chips,Scratches...
    The Art of Bodge-It Never Fails.
    apriliaforum expert D-Rider's Avatar
    Jul 2005
    Coventry, England
    I've done it with my Falco but never yet needed to do so with the Futura. I don't imagine it would be any more difficult.
    However, it takes a lot of effort and isn't that easy so best to fix the underlying problem as soon as possible.
    The trick to bump starting any large bore bike is to first push the bike backwards in gear till you bump up against compression. Then the engine is in a position to allow it to easily start turning before hitting a compression stroke.
    Sep 2017
    St Louis MO
    Following up on this: I decided to not bother with push-starting, and instead got some jumper cables.
    Since there's so little room under the seat I took out the standard took kit and replaced it with the cables - I figure I'm more likely to need and use that than any of the tools.
    (Although that may be a sure way to get the bike to start on the first attempt, have the battery live forever, and result in the first on-the-road failure being one where I need something in the tool kit.) If I ever do any long-distance riding with the luggage on I'll toss the tools in, if I don't misplace them in the meantime.)
    apriliaforum expert thesprocket26's Avatar
    Oct 2012
    SW Idaho, USA
    What have you done to solve the original problem? Was it battery? Stator? Reg/Rec? What were your charging voltages?
    If your idea of sport-touring is multi-position seats, cruise control and electrically-adjustable windshields, you’re probably not Italian and you don’t deserve a Futura. - Kevin Duke
    2001 RST1000 Futura
    Sep 2017
    St Louis MO
    Quote Originally Posted by thesprocket26 View Post
    Short answer: Nothing conclusive yet, but hopefully I'll soon have more info.
    Long story: When I was last working on this issue I accidentally blew the fuse in the pigtail I use to charge the battery with my CTEK charger. (I was going to use that cable to connect to the Battery Tender voltmeter I got specifically for this task.) I was running out of daylight so I had the choice riding the bike or taking the time to root around in the basement for a replacement fuse (which would have been too high amperage anyway). So I decided to just ride the bike instead of doing the voltage check. Since then I've been busy, and with the early sunsets haven't had the time to mess with it.
    apriliaforum expert Motech's Avatar
    Aug 2006
    Santa Cruz, CA
    I've never even tried push starting this pig. FWIW, only way it works is if ECU still sees minimum 8 volts. Spark too weak and injectors won't get enough inductive kick to open very well, and I don't know about Sagem, but most systems flat won't trigger anything at all under 8 volts. If you do try, listen real close near your left knee when you sputter to a stop and you'll hear that focker laughing at you.
    No Matter Where You Are, There You Go!
    apriliaforum expert rdbandkab's Avatar
    WV... Northern Panhandle
    I took the Fut'r for a short ride to get the liquids circulated.. Oops.. No start! I had purchased a cheapie battery about 4 years ago and it finally gave up. To be fair, the Futura doesn't see too many miles lately...and I don't keep the tender on her all the time. I used one of the little Li jumper batteries. Started right up!
    02 aprilia Futura
    15 aprilia Caponord 1200
  1. how easy is it to snap a crash bobbin?
    By hornetear in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 09-13-2011, 12:12 AM
  2. how easy is it to derestric?
    By jordan_310 in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 06-14-2006, 05:38 PM
  3. How hard is it to redo the forks? New springs and valve kit.
    By mysubaruimp in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-30-2005, 03:01 PM
  4. How easy is it to check and adjust the Valve timing in the 04 RSV?
    By scott2ride in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 10-04-2004, 04:16 PM
  5. How easy is it to de-sticker a bike??
    By Rick H in forum RS125 Euro-archive
    Last Post: 02-23-2004, 09:22 PM
