Results 1 to 15 of 27
Thread: How easy is it to push-start a Futura?
    Sep 2017
    St Louis MO
    After over-night charging the starter spins up fine and the bike starts with no problems.
    While out on a ride (say, an hour or so) and a few starts later, I get slow cranking, but enough to get it going.
    (I bought the bike a few months ago and haven't yet checked to see if the wiring-mods have been made, but I don't think so.)
    If it's easy to push-start then I'll keep riding it a bit longer before I check things out, especially if riding with my buddy, who can give me a shove.
    If it isn't easy to push-start I'll try to figure out the problem much sooner.
    Also, I assume 2nd gear the best one to use, is that correct?
    apriliaforum expert VFR4Lee's Avatar
    Sep 2008
    Sitting on a park bench. Eyeing little girls with bad intent. Channeling Jethro Tull.
    The ECU needs juice. Will it push start at all?
    Replace the battery.
    Plus, get something like this.
    https://www.amazon.com/Bolt-Power-D2...rds=bolt+power
    My Tuono suits me to a "T".
    Thunder!
    Sep 2017
    St Louis MO
    Quote Originally Posted by VFR4Lee View Post
    Thanks for the suggestion.
    I'm hoping that the ECU will still operate at voltages / power that are lower than what's needed to crank the motor, so hopefully a low battery will be good enough, assuming the power to move the pistons comes from elsewhere.
    My first attempt to fix things will be to check the R/R wiring, I probably replace both the wiring and the R/R, assuming that hasn't already been done.
    I also want to check the electrical connections at the starter. If all that checks out OK I'll replace the battery.
    The main problem is that I need to do some major rearranging in my garage in order to have room to work on the moto, and I'd rather spend my free time riding than cleaning out the garage...
    Sweden, Linköping
    You need a steep hill. Push start on your own without incline may work if you are an olympic sprinter champion.
    Sep 2017
    St Louis MO
    YPush start on your own without incline may work if you is an olympic sprinter champion.
    Which I am not. I was wondering if having a buddy to push it would be enough, but it sounds like that's iffy.
    I guess I need to be careful, and figure out why I'm having this slow cranking issue...
    apriliaforum Junkie Corsehf's Avatar
    Jul 2006
    Worcestershire - UK
    You need a steep hill. Push start on your own without incline may work if you is an olympic sprinter champion.
    Is it actually possible??
    I tried to bump start mine on a hill once when the battery died and had two attempts. First one in second gear but all that did is lock the back wheel up and stop the bike and the second attempt was in third and I got nothing - not even close?
    I then begged for a jump from a passing car.
    Andy
    Current: 2002 Futura RST in Silver
    Datatagged, 05 Map, Metal QD, H Pipe, Bef Cans, RSV De-restrictive Snorkel, RSV Forks & Brakes upgrade, NGK DCPR8EIX Iridiums, Earthed Throttlebodies, FPR Mod, Vee Max Starter Solenoid with uprated cables, FH008EE RR & Wiring Mods, NWS Hugger, Oxford OF691 Touring Hotgrips, Accessory & USB Sockets, HID Headlight, Pirelli Angel GT's
    Up in Flames: 2001 Futura RST in Blue
    Datatagged, 05 Map, Skidmarx DB Screen & Hugger, K&N Filter, Brown Connectors soldered, R&G Hotgrips,
    Acumen DGV, Scottoiler, Accessory Socket. BikeVis Bullets
    Sep 2017
    St Louis MO
    Quote Originally Posted by Corsehf View Post
    I'm thinking this might be the easiest way to go.
    Yesterday after gassing up at the end of my ride it just barely turned over when I was ready to go. At least at a gas station one's likely to not have to wait too long for a jump. Until I get this fixed I think I'll have to plan my stops more carefully and do so where I'm likely to find help.
    Jul 2006
    Worcestershire - UK
    Quote Originally Posted by spin10k View Post
    The Rotax twin does need a fair bit of current to spin it over and some do sound very slow.
    A decent battery is a must - the Yuasa YTZ14S is highly recommended.
    An upgrade on the starter solenoid will also help.
    Also, I have doubled the ampage of the cable running from the battery to the starter solenoid and then from the starter solenoid down to the starter.
    All of the earth cables were doubled too.
    My bike starts up immediately now - every time.
    Andy
    Jul 2006
    Worcestershire - UK
    Whilst your bike is running, have you checked the voltage at the battery?
    Andy
    Sep 2017
    St Louis MO
    I did a while back (before I bought it) and I seem to remember it was 14.1 V, but I'm not 100% sure that's correct. (Might have been 13.1 V)
    I need to check it again. I know 13.1 is pretty low and 14.1 is close to being OK.
    Jul 2006
    Worcestershire - UK
    13.1 is about standard for a Futura that has not had the charging mod done whilst 14.1 is fine
    What is the state of charge in the battery before you try to start the bike? - most people now fit a voltmeter just to keep a check on the state of the battery.
    Andy
    Sep 2017
    St Louis MO
    When I first start it it's presumably fine, because it's been on the trickle-charger overnight and the starter spins very well. For later starts during a ride I don't know, I haven't installed any additional instrumentation. (I know this doesn't mean too much, but after one week of sitting without charging if I plug in my CTEK red-yellow-green indicator (not the charger itself) I do get a flashing green LED, not yellow, which means that the voltage hasn't dropped too much.)
    apriliaforum prov-nov bisy's Avatar
    Nov 2007
    Melbourne, Australia
    Could not push start mine even with the help of a couple of mates. Had to buy jumper leads
    Sent from my iPhone using Tapatalk Pro
    Sweden, Linköping
    You have to jump down on the seat at the same time as you release the clutch to get enough tyre friction.
    Jul 2006
    Worcestershire - UK
    Never an issue, I used to race Grass Track & Speedway back in the day and trying to start a 4B JAP and a 500cc Weslake on a wet field with a steel shoe was an art!!
    Andy
  1. how easy is it to snap a crash bobbin?
    By hornetear in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 09-13-2011, 12:12 AM
  2. how easy is it to derestric?
    By jordan_310 in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 06-14-2006, 05:38 PM
  3. How hard is it to redo the forks? New springs and valve kit.
    By mysubaruimp in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-30-2005, 03:01 PM
  4. How easy is it to check and adjust the Valve timing in the 04 RSV?
    Last Post: 10-04-2004, 04:16 PM
  5. How easy is it to de-sticker a bike??
    By Rick H in forum RS125 Euro-archive
    Last Post: 02-23-2004, 09:22 PM
