Page 1 of 3 123 LastLast
Results 1 to 15 of 33
Thread: 900cc VS 750cc on dyno
    37 miles E. of ATX, TX USA.
    Here are the basic dead stock dyno runs of the 900cc vs 750cc 90 degree v-twin motors from the Shiver/Dorso. Do not get hung up on low looking numbers, our dyno reads about 15% lower than what you will see on a DynoJet dyno, this is quite simply RAW bhp and torque at the rear tire corrected only for atmospheric conditions, no BS fluff factor like powertrain or driveline loss etc. The awesome news is that the gains are well in excess of what was initially claimed by Aprilia/Piaggio from the extra 150cc of cylinder displacement.
    The Dorso used for baseline testing made some pretty photogenic pics during it's break in time a few weeks prior to doing full power runs. The red hot pipes are totally normal in extended cruise power type running, with air injection filling exhaust with fresh air to burn off any remaining unburnt fuel from combustion chambers and working with the catalyzer to clean up tail pipe emissions. Makes for neat looking pics so I figured I would shoot a few and share them.
    Long story short the new 900cc motor is well up on power compared to the 750cc unit replaces, it responds well from very low rpm which is nice on the street and pulls to the top of the rev range eagerly!
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Oct 2009
    that's quite a jump..and good news ...love the glowing exhaust
    Aug 2010
    Denmark
    Nice graphs - thanks.
    How is the AFR doing ?
    Any area that can be improved ?
    Dorsoduro 900
    There is ZERO point in trying to measure af/r on a new demo bike with air injection active...simply erroneous data. As time goes on I will explore a little deeper into this, it will require some more work than I have time for ATM like adding a couple of header bungs for widebands and killing off air injection to see where we are really starting at.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Jul 2007
    Kapiti, New Zealand
    Thanks Micah
    Surprised by the jump in torque and power!
    I'm happy with my 750 Shiver (other spending priorities....), but that extra grunt would be nice!
    Frodo
    2015 Shiver
    New Zealand
    apriliaforum expert Hellgate's Avatar
    Mar 2009
    AUSTX
    Impressive
    How's the dyno room compare to the old one?
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Pete
    Apr 2010
    Denver, CO
    Nice little bump there. Micah, you can speak to this but is it just the design of the engine and the cams that hold these things back? I look at the Ducati Streetfighter 848 which I would guess puts down 110 or so on your dyno (120ish on a Dyno Jet) and really wish that these could at least split the difference. The ducati 939s are doing 100ish on most dynos so still a bit more then these bikes... I just wish Aprilia had a stop gap bike between the Shiver/Dorso and the Tuono. I would really love a 465lb, 115hp, naked...
    Aug 2015
    Gilbert, Arizona (USA)
    I'd like to know about the cam lift and duration on the 900's. If they're better, could they be dropped into the 750 heads for some sought after gains?
    Interesting question on valves and heads, I have not had any reason to take one apart, apparently the change was in stroke only between the 750 and 900 so there could be some differences.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Aug 2015
    Well... if you happen to find a reason to tear into one (AF1 race Shiver project from a while back, hint) please keep us posted.
    apriliaforum prov-nov ExMXer's Avatar
    Aug 2013
    North
    I would like to know what the mileage is on both bikes.
    To what mileage does the computer restrict output during break-in?
    Apr 2010
    Denver, CO
    Quote Originally Posted by ExMXer View Post
    To my knowledge the ECU does not restrict power at all during break in. The manual states you should take it easy but I think you still get the full power.
    With that said, most guys who race, work on, run lots of bikes don't really follow break-in instructions from what I have seen.
    The typical method seems to be:
    -Run them hard but not to full rpm, think 3/4 throttle to 3/4 rpm for the first couple hundred miles
    -Don't maintain steady rpm, lots of accel/decel to load the rings
    -Change the oil/filter after 25-50mi and again at 500-1000mi
    -Use non-synthetic for the first 1000 miles then switch over to syn.
    I saw zero computer restriction on either bike, both were AF1 demo bikes, both had several hundred street miles at time of dyno testing, will add 1200cc into mix...also dead stock demo bike on first mapping option as I ran before and after loading Arrow race mapping and stock 1200cc mapping was terrible here in USA "as -delivered". These dyno runs obviously only reflect full throttle where the mappings of all test bikes were in an acceptable af/r range, neither drowning rich nor scary lean.
    The 1200cc Motor truly towers above the 750 and 900cc versions lol.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Just an FYI, every motor sold before ever being installed into a car, boat, airplane, motorcycle or scooter has been run to full power on a motor dyno to make sure it is fundamentally "good". My basic break rules are only this, ride it like you are going to ride it, vary rpms and MAKE DAMN SURE IT IS FULLY UP TO OPERATIONAL TEMP BEFORE BEATING ON IT. That last part is REALLY important no matter whether a motor is old or new. The only parts really "breaking in" on modern engines are the piston rings and since they are pushed out towards the cylinder walls by combustion pressure, getting on a motor is good for it during break in, at least up to peak torque rpm. I have never had a properly built "new" or "rebuild" motor fail on the dyno and many people get machines modified and tuned before even taking delivery.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    apriliaforum expert drvacation's Avatar
    Aug 2013
    las vegas
    WORD! Been building trick Motors for years,let it warm up and ride it like you stole it. No blow ups, no oil burnersSeen a lot of people burning oil say I broke it in per factory instructions
  1. SXV vs Husky on the dyno
    By Ed / AF1 Racing in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 05-20-2008, 06:52 PM
  2. Capo vs KTM950 on the AF1 Dyno
    By Micah / AF1 Racing in forum ETV1000 CapoNord (2001-2007)
    Last Post: 07-28-2006, 06:40 PM
  3. Im Mad, Zip On Dyno
    By Ethro in forum RS50 Technical
    Last Post: 09-05-2005, 08:22 AM
  4. Dual vs Slip-on
    By lizard in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 12-24-2004, 01:52 PM
  5. my RS 125 on dyno ..
    By rossirep in forum Aprilia Owner's Pictures, Videos, and Sounds
    Last Post: 10-11-2004, 01:29 PM
