Results 1 to 15 of 16
Thread: 17 dash update without flashing ecu map
    Jun 2017
    Frederick MD
    So looks like to get my v4 mp working I'll need to get the dash and v4mp module updated. But I'm getting the akra with codes this winter and concerned that doing the dash update will result in a min race map being added to the bike. Should I wait until after the dash update to get the akra and race codes
    Westminster, CA - USA
    Update the dash, the MP and the ECU to the latest software.
    When you get the Akra w/unlock code, update the ECU again.
    Or wait till you get the Akra code and update everything in one trip.
    apriliaforum Junkie prettykin's Avatar
    Mar 2011
    L.A.
    This Dash update BS is starting to get old fast... My v4 MP has been giving me all sorts of problems since I got the back 2 months ago. In Fact AF1 almost had to postpone shipping the bike because of a last min dash update, I was still having problems so i brought the bike to my local dealer and they perform an additional dash update to get the device working a little bit better, and now The app has been updated and now I need a 3rd update in order to use the system at all now 3 days before an upcoming track day which, is the whole reason I purchased the unit in the first place! If I have to pay for one more update I'm gonna loose it!
    I don't blame you for being frustrated, but without knowing what version software is on your dash and MP-2 unit right now, we can't say much.
    The MP-2 update is quick and easy, takes longer to unbolt the seat and side panel than the actual firmware load.
    I've updated a few and there is no charge for the update.
    I'd be surprised if Victor won't help you out.
    Mar 2011
    L.A.
    Moto club updated my dash a few weeks ago and things improved a bit. The tech explained that most many of the problems lay with the app itself and an update to the app was needed to iron the bugs. My iPhone app auto updated itself a few day ago, the first I tried to use the app to connect to the bike it show a message saying the software on my dash wasn't compatible with the latest app update and I would need to see my dealer for a dash update to restore functionality. So until I get the dash updated I have zero functionality.
    Jun 2017
    Frederick MD
    Amauri, to do the mp update do they use the dash connector, the regular diag connector, or to the v4 mp module itself?
    plug the PADS directly to the MP module connector on the LH side of the subrame
    Sep 2016
    SW England
    I got my 2017 in May, not had any update done (unless they did one at 1st service in June?) I have no trouble using my V4 app at all, it does all the datalogging, phone calls appear on it - am I just the lucky one ?
    Nov 2016
    Ontario
    Mine was working great until my iPhone pushed the new update to the app. Now I’m stuck going in for an software update before I can use v4-mp again. But it’s nearly the off season here and I didn’t use it too often. Won’t hurt to get the dash updates at the same time. I just hope my dealer is capabale enough to keep from giving my ecu an updated stock map, I’m already running the race ecu.
    Jun 2017
    Frederick MD
    How about the dash update? Is it that little plug under the seat that is white with three pins? Or does it use the diag connector?
    for a 17 bike use the grey connector that goes to the MP-2
    for a 16 bike use the white connector with 3-pins
    Jun 2017
    Frederick MD
    That's cool. So you plug into the dash side of that harness to do a dash update or the mp side to update the mp module.. fair enough. Just making sure I have the info to get this all done at the beginning of next season. Thanks Amauri!
    do you have a PADS and special cables?
    Jun 2017
    Frederick MD
    Negative.. gonna go to my dealer. I do have lonelec cables and guzzidiag. I'm doing a slipon and race ecu this winter so I can do my own throttle and handle learning. But I'll be going dealer for updates. Debating on whether to do the race edu before or after the updates. I'm worried they may accidentally put stock map on.. I wish I had pads.. I'd buy it if piaggio sold them to the public lol
    Jun 2017
    nyc
    Is it correct to assume a dash update or MP update has no effect on the ECU?
  1. removing flashed Race Map from Std ECU
    By alol in forum 2010-2018 RSV4 - All Variants
    Last Post: 09-19-2016, 01:55 PM
  2. ECU Map update
    By G3ORG3 in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 11-26-2010, 02:26 AM
  3. ECU Map Update ?
    By bjhughes in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 02-02-2009, 01:03 PM
  4. ECU/Map 2 Updates
    By Harpys01 in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 11-24-2006, 07:43 PM
  5. Updating Ecu Map
    By JRTURBO in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 03-02-2004, 07:17 PM
