Results 16 to 21 of 21
Thread: Dash Problems
    Mar 2016
    Oxford
    That's a 10 Ohm resistor.
    Oct 2017
    Sydney
    awesome, thankyou. You wouldn't by chance know where I can source a 189 name value resistor? (18Gohm). The closest I can find is 20Gohm from Element 14. Mouser and others don't go that high. No one in Australia has them.
    cheers
    Steve
    Mar 2016
    Oxford
    18G Ohm!!!!
    Can you post up a pic of the resistor your looking at on the dashboard ....... from memory the biggest resistor used is only 150K Ohm
    Oct 2017
    Sydney
Name:	pcb resistor 5.6.jpg
ID:	347396 the missing resistor on the right hand side has a 189 value ? 18^9 ? cheers cheers
    Mar 2016
    Oxford
    Ah .... I get it now! You've been reading it upside down .....
    it's a 681 - 680 Ohm resistor. That's the 12v supply down to the speedo sensor.
    Oct 2017
    Sydney
    thankyou Sir, you are a lifesaver, I didn't pick the upside down 1... crazy. so im guessing that might explain why the odometer is not working. Ive got the needles removed so i didnt pick up the speedo movement or lack thereof on the road test.
    again, many thanks...
    cheers
  1. dash problems
    By hagasn in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 05-13-2007, 09:46 PM
  2. Weird dash problem
    By dizzyg44 in forum SL1000 Falco Forum (all years)
    Last Post: 11-27-2006, 12:00 PM
  3. Urgent Help Required - Clocks / Dash Problem
    By PBoroMille in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 10-04-2006, 02:27 PM
  4. Mille R dash problem?
    By ronnie simpson in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-07-2005, 05:04 PM
  5. Dash Problems
    By BossBob2 in forum RST1000 Futura (all years)
    Last Post: 07-09-2003, 05:20 AM
