Results 1 to 15 of 23
Thread: OpenFlash Tablet Official Dyno Results: 2014 RSV4 R
    Aug 2017
    Danville, CA
    Red face OpenFlash Tablet Official Dyno Results: 2014 RSV4 R
    A couple of weeks ago, we finished developing calibrations for the 2014 Tuono. Here is our Stage 2 calibration (for use with slip-on or full Akra Evolution exhaust). Like the Race ECU calibration in the 2017 Tuono, the Race ECU calibration in the RSV4 ran quite rich on some cylinders an lean on others. Correct the fueling issues, adjust max throttle limits, revising spark timing tables and bumping rev limit slightly made some nice gains. This tune has been tested by myself and another customer (also on this forum) at Thunderhill a couple weeks ago and we were happy with the improvements. Significantly more drive coming out of corners and smoother transition from engine braking to neutral throttle.
    Details:
    91oct fuel
    1) 100% stock 2014 RSV4 R (Blue)
    2) With Akrapovic Slip-on and Aprilia Race ECU calibration (Red)
    3) With Akrapovic Slip-on and our OFT Stage 2 off-the-shelf tune (
    Green)
    In the Garage:
    2018 Panigale V4 S (coming soon!)
    2017 Tuono Factory
    2016 KTM RC390
    2015 KTM 1290 Superduke R
    2014 RSV4 R
    2011 Ferrari 458
    2013 Scion FR-S
    2016 AMG GT S
    2016 Mazda MX5
    2016 Mazda CX5
    2017 Charger Hellcat
    OpenFlash Tablet
    Free Tunes || 3-Touch Programming || Digital Gauge Displays || Datalogging || Handheld Convenience || No Laptop Required
    Oct 2015
    Tasmania
    It will be very interesting to see what gains you achieve with the '16 RSV4 RR/RF.
    Aug 2017
    Danville, CA
    That's coming up next. Mapping a 2016 Tuono tomorrow. And the 2016 RSV4 next week probably.
    In the Garage:
    2017 Tuono Factory
    2016 KTM RC390
    2014 RSV4 R
    2011 Ferrari 458
    2013 Scion FR-S
    2016 AMG GT S
    2016 Mazda MX5
    2016 Mazda CX5
    OpenFlash Tablet
    Jan 2015
    Melbourne, Australia
    I have a 14 RSV4 with the race ecu and slipon can and it definitely runs rich. Do you know if the rich/lean cylinders is common for all 14 RSV4's or does it vary bike to bike? Wondering if installing your map would work or if it needs to be individually tailored to each bike?
    Aug 2017
    Danville, CA
    Quote Originally Posted by aussieRSV4R View Post
    Sorry, I just your question now. There may be some bike to bike variance based upon variables like injector flow and engine tolerances but they should be fairly minor. So I suspect all equivalent RSV4s to behave similarly to mine. But it's always nice having the option to take the bike to a dyno and adjust our calibrations if needed. All our tune files are unlocked so you can use our free tuning interface to make changes to fuel, timing, throttle, limiter, etc, tables. It's very flexible.
    In the Garage:
    2017 Tuono Factory
    2016 KTM RC390
    2014 RSV4 R
    2011 Ferrari 458
    2013 Scion FR-S
    2016 AMG GT S
    2016 Mazda MX5
    2016 Mazda CX5
    OpenFlash Tablet
    apriliaforum prov-nov boofhead187's Avatar
    Jun 2016
    Australia
    Quote Originally Posted by OpenFlash View Post
    So do you have to buy the OpenFlash Tablet in order to get access to the tuning maps ?
    Do you have custom maps to suit multiple exhausts or just 1 to suit the Akrapovic ?
    Oct 2015
    Tasmania
    Quote Originally Posted by boofhead187 View Post
    I'll try to sum it up for you.
    You buy the Tablet & then the tuning software & maps are free.
    Comes with equivalent to Aprilia Race mapping for Akra + OFT stage 2 tune as far I know. That last one is Shiv's tweaks to the Race ECU mapping, you can load & play around with both & have access to any maps that get to his map library when they become available.
    This may help http://www.openflashtablet.com/install/oft-faq/
    Jun 2016
    Australia
    ok thanks for the summary.
    Dec 2015
    Cape Cod, MA
    Just curious if the cylinders were individually mapped?
    Instagram: 0p3ragh0st
    Austin, TX
    Quote Originally Posted by 0p3ragh0st View Post
    yes, all 4 cylinders.
    In stock now, http://www.af1racing.com/store/Scrip...dProduct=92483
    Jun 2016
    Australia
    Hi,
    So I've applied the stage 2 map along with an arrow gp2. Things I've noticed over stock
    1. pulls harder from around 5000rpm
    2. engine braking is significantly increased
    3. throttle smoothness is gone, very jerky in 1st gear (this is the only annoying thing, I just had my bike serviced and throttle adjusted and it was silky smooth prior to this)
    I also have an error on the dash and TC is not working, tried to re-calibrate drove up and down doing 40km/h and calibration notice wouldn't go away.
    They also gave me the RaceECU map , once I've plugged in the GuzziDiag and worked out what the error is with TC/Calibration , I'll swap over to compare.
    Jun 2016
    Australia
    No faults reported by GuzziDiag. so I have no idea why the amber light on the dash and TC not working ?
    Oct 2015
    Tasmania
    Amber light solid & a dash on the dash, would be indicating TC is just turned off if no faults.
    Can you get it to turn back on by holding the plus button for a couple of seconds?
    Aug 2017
    Danville, CA
    *this*
    In the Garage:
    2017 Tuono Factory
    2016 KTM RC390
    2014 RSV4 R
    2011 Ferrari 458
    2013 Scion FR-S
    2016 AMG GT S
    2016 Mazda MX5
    2016 Mazda CX5
    OpenFlash Tablet
    Oct 2015
    Tasmania
    *this*
    yep, he PM'd me & said it turned back on as I suspected.
    Thanks for being persistent & dealing with the confusion which can come from inexperienced owners & hearsay, it's got to be frustrating for you at times.
  1. OpenFlash Tablet Official Dyno Results: 2017 Tuono
    By OpenFlash in forum 2012-2018 Tuono V4 - All Variants
    Last Post: 07-11-2018, 12:20 PM
  2. OpenFlash Tablet Official Dyno Results: 2014 RSV4 R
    Last Post: 10-13-2017, 07:43 AM
  3. [RSV4] 2014 RSV4 OEM Sachs shock absorber - Excellent condition [Texas]
    By jrD in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 12-02-2015, 01:32 PM
  4. [RSV4] 2014 RSV4 Factory Engine Parts
    By dastrix in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 02-03-2015, 04:55 AM
  5. [RSV4] WTB: 2013 or 2014 RSV4 Fuel Tank
    By beckett_bgs in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 11-24-2014, 09:29 PM
