Results 46 to 54 of 54
Thread: Factory Heated grips
  1. #46
    Sep 2017
    Far Eastern Pacific
    Perhaps Italian heated grips are tested for Roman winters and not Glasgow? Much the same as Jaguar XKE cooling systems were a bit under-spec'ed for San Bernardino County summers.
  2. #47
    Feb 2014
    Bozeman, MT
    That could be. I was out yesterday in 34 degree weather and they felt barely warm. The BikeMaster ones I put on my Dorsoduro would roast your hands off in that temp.
  3. #48
    apriliaforum Member heinz57's Avatar
    Oct 2016
    surrey, UK
    Going back to an earlier post. I've just had my dealer fit Oxford grips and wire them into the Aprilia Button so that the screen display and button operate them without the addition of the Oxford control switch. OK so I lose 2 of the five settings, but a very neat installation. Onyerbike, Aylesbury are doing a good deal at the moment 135 for the grips and the fitting.
    Haven't tried them yet as told to let the glue cure before use.
  4. #49
    Jul 2017
    Yorkshire Coast
    Quote Originally Posted by heinz57 View Post
    Please let us know your thoughts when you've had chance to evaluate them thoroughly. I assume if they are wired through the bikes own wiring you will lose the heating effect under 2000 rpm? I've noticed you can pick up a full Oxford kit for under 50 on fleabay, I wasn't going to bother changing them as the majority of my riding is in the summer months, but if they are better for that kind of money I think I'll try them myself
    40 odd powered two wheelers over 40 odd years. Currently in the garage are a 2016 Tuono V1100RR and a '79 Honda CB550F
  5. #50
    Oct 2016
    surrey, UK
    Had my first ride out in 5C weather with the new heated grips on. Set on level 3 they warmed up quickly and kept my hands warm. Sorry I cannot compare them to either the Aprilia grips or Oxfords through their own switchgear as I have not used hot grips before. Not sure that I will ever use level 1 or 2 but 3 does the job.
    As the Oxford grips are wired through the stock Aprilia wiring, yes they temporarily switch off under 2000rpm.
    Took a run out the next day in similar temp. tried the grips on 1, very subtle heat, almost like the heat your hands self-generate in good gloves. Heat setting two, noticeable but I see no reason to use this over heat setting 3.
    If you need your hands warming use a setting which warms them.
    I am definitely a convert to heated grips now.
  6. #51
    Jul 2017
    Yorkshire Coast
    There have been a few good offers on Oxford grips recently (here in the UK anyway) so I'm going to get a set and do what heinz57 has done and wire them up to the Capos existing set up.
  7. #52
    Oct 2016
    surrey, UK
    can you post a picture of the Aprilia grips as fitted, I have been told that they are a neater fit than the Oxford ( only in so far as the Oxford grips have a cable housing prominent on the grip) I'll post a picture tomorrow.
  8. #53
    apriliaforum newb Capo-Wello's Avatar
    Aug 2017
    Wellington NSW Australia
    My Rally with factory heated grips
    Name:  2017-11-29 19.13.42.jpg
    In the shed - Caponord Rally, Cagiva Navigator, DR-Z 250, DR 500z
    In the past - CB 250 (Hawk), CB 750 (K2 & K7), Kawa z650, Bol'dor 900
  9. #54
    Oct 2016
    surrey, UK
    .Click image for larger version.
Name:	heated grip left.jpg
ID:	347185Click image for larger version.
Name:	heated grip right.jpg
    I can live with the minor differences. Attached is my the Oxford grip installation
    Note to self. Must clear out some crap from my garage!
  1. New in box factory heated grips CAPONORD
    By Kraig D in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 10-09-2013, 09:09 PM
  2. Sport 1200 - Factory heated grips query
    By OZSLR in forum Moto Guzzi Motorcycles
    Last Post: 06-30-2013, 05:45 PM
  3. Factory heated grips
    By RPB in forum RST1000 Futura (all years)
    Last Post: 09-19-2004, 09:32 AM
  4. Factory heated grips
    By RPB in forum ETV1000 CapoNord (2001-2007)
    Last Post: 09-17-2004, 06:26 AM
  5. Factory Heated Grips?
    By xbmwrider in forum RST1000 Futura (all years)
    Last Post: 12-28-2003, 04:25 PM
