Results 1 to 13 of 13
Thread: Engine cut out on a new Tuono only done 650 miles
    Sep 2017
    Nottingham UK
    I was tip toeing along today in traffic doing about 30mph in 2nd or 3rd, don't recall and the engine just simply cut out. Because I was so surprised I'm not sure whether I down shifted, pulled the clutch or went from 2nd to 3rd etc, but it simply died on me and it felt like there was no engine breaking. I hit the 'starter' button and it fired up again and I carried on.
    I'll pay more attention next time if it happens, but wondered if anyone else had experienced this behaviour. Bit worrying considering I've not even had the bike 1 week yet and its not even done a 1000 miles yet.
    Just to add more info. I had put in Tesco momentum in about 2 miles before which has a 99 Octane. However ran this fuel on my previous Honda for 30k without problem. Bike was warmed up and not at altitude.
    apriliaforum expert comfysofa's Avatar
    Sep 2012
    Bristol, uk
    No problems with Tesco high octane in my rsv4 factory.
    Sent from my SM-G955F using Tapatalk
    Mar 2017
    UK
    If it was on clutch pull. Have a read through this...
    http://www.apriliaforum.com/forums/s...ming-to-a-stop
    May 2016
    Liverpool
    I can't beleive dealers are letting new bikes out now without updating the software knowing that it will only come back because of said issue
    apriliaforum expert Jaybe's Avatar
    Jan 2016
    Highland Scotland
    Quote Originally Posted by shabba007 View Post
    If you havent already get the charcoal cannister removed mine done the same always when hot in traffic never did again after removal.
    Current bike
    V4 1100 Factory 2017
    If you have anything good to say shut the fuck up!
    Sep 2017
    Nottingham UK
    Quote Originally Posted by PaulFargo View Post
    Assume you know something on this subject. Is it software related ? and is there a way of knowing if I've got the latest software or not. Version number or something ?
    May 2016
    Liverpool
    I would assume the dealer would connect the bike to to PADS during the PDI which should then update to the latest software.
    apriliaforum Junkie Pycha's Avatar
    Jan 2017
    Czech rep.
    I have the same experience with my now tuono. It was around the first 500km. Now I have 10000km without a problem.
    but I have the same experience with both Yamaha and Suzuki, so it's probably normal with the new bike
    May 2017
    Chicago, IL
    Assuming the dealer is updating their PADS software or regular basis
    Sep 2017
    Nottingham UK
    will the dealers remove the charcoal canister or is it a warranty issue ?
    Jan 2016
    Highland Scotland
    Your dealer will remove it under warranty they know there are issues with fuel pressure and hot cut outs on some bikes because of it. My dealer was aware and removed no problem no charge.
    Current bike
    Sep 2017
    Nottingham UK
    its worth checking you've got the latest software as I've just found out that after 1000 miles my software hadn't been updated since leaving the factory even though the dealer I brought it from stamped the book with first service. Makes me wonder if they even changed the oil!
    Hopefully this might resolve my cutting out issues in 1st gear when pulling up.
    I won't mention the dealer. If someone wants to PM me I'll let you know.
    Jul 2017
    Northwest Indiana
    Had a similar issue with our dealer.....
  1. Engine cut out on move
    By Smeeinnit in forum SL1000 Falco Forum (all years)
    Last Post: 09-19-2017, 10:20 AM
  2. Engine Cut Out/Stalling - Does the 2013 New Map update fix
    By Troytheboy in forum 2012-2018 Tuono V4 - All Variants
    Last Post: 04-08-2014, 10:53 AM
  3. ugh, new scooter cut out on a busy road today
    By glasshalffull in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 11-12-2012, 04:14 PM
  4. Engine cuts out on closed throttle
    By Iagu in forum 2006+ Pegaso Trail / Strada / Factory
    Last Post: 07-14-2008, 03:15 PM
  5. engine cutting out over bumps etc
    By bumblepoo in forum SL1000 Falco Forum (all years)
    Last Post: 06-30-2003, 06:12 PM
