Results 1 to 9 of 9
Thread: Triple Tree Cap Ram Ball Mount
    Oct 2003
    NUNYA, USA
    Looking for some help from anyone out there who has been able to source a Screw-In replacement Steering Head / triple Tree Cap for an early model
    Ohlins setup, that will accomodate (incorporate) a regular sized RAM Ball mount.
    See attached pictures for What I'm looking FOR:
    And again, I'm looking to REPLACE the screw-in cap with a cap that has a threaded RAM Ball mount for a Cell Phone mounting on my bike.
    Odd request, but I dont know if one of these exists???
    Thanks for anyone's help!
    grName:  CO14NUT(1).jpg
Size:  57.9 KBName:  CO14NUT2.JPG
Size:  22.1 KBName:  CO14NUT(1).jpg
    apriliaforum Junkie dasrider's Avatar
    Feb 2013
    Central NC
    I've not seen a replacement steering stem nut with a pre-threaded hole for a ram-mount ball like that before - that does look pretty cool. I've only seen the style that you insert and expand the rubber.
    Personally, I use their universal u-clamp on my right clipon. I also use Apex adjustable bars so I believe they are a bit longer than stock so there is just enough room to make it happen. Makes a nice spot for my cellphone.
    Dec 2012
    Paimio, Finland
    Black gaffer tape and cable ties do it for me.
    The part you illustrated there looks nice. If you have a machining shop nearby you could have one made.
    If you find one ready made, do not keep it as a secret.
    Mille Aarrr -02 & KTM 625 SXC -05
    Jan 2013
    Carlsbad
    This is what I did. I got some hex stock and made an expanding clamp. There are RAM balls that have a through bolt, and I used that to expand the clamp.
    The supplementary dash is a work in progress.
Name:	Aprilia RAM mount.jpg
    Dec 2012
    Paimio, Finland
    Like a bar end expanding clamp. Clever.
    apriliaforum Member amok's Avatar
    May 2017
    straya
    2016 Tuono 1100 RR
    2015 S1000RR
    Mar 2012
    Brooklyn, United States
    Is the RAM mount secure in the hex stem?
    https://www.rammount.com/part/RAM-B-176-A-UN7U
    Mar 2012
    This is great, I'm a novice DIY'er can you tell me the right parts to get so I can make one too. I don't know how to make a hex socket expand... Tks!
    Jul 2007
    Middletown, CT
    Easiest way I can think of is to cut the hex stock in half at an angle. Loose clearance hole one piece and thread the other. Run the bolt through the clearanced piece and into the thread. When you tighten the bolt the angled cut will cause the two pieces to shift laterally relative to each other which will wedge them both into place.
    I'm on the app store! Check out Solitaire: Slide it's free!
  1. [RSV4] Upper triple tree, ignition switch, key, and fuel cap
    By tomik in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 05-15-2016, 04:06 AM
  2. [Mille] FS: early Mille R 51mm Ohlins forks and triple tree complete, axial brake mount
    By Chamberlin in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 07-30-2015, 11:57 PM
  3. Handlebar bolts, RAM ball mount
    By jaldridge in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 08-10-2012, 06:49 PM
  4. Best Ram Ball Mount for a 2006 Tuono?
    By stoney in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 03-24-2009, 06:35 PM
  5. Triple tree's ??????
    By duc slayer in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 04-02-2004, 12:09 AM
