Results 1 to 3 of 3
Thread: Sr 50 r cutting out
    Sep 2017
    Uk
    Sr 50 r cutting out
    Hi everyone
    my 2011 sr50r has been faultless until now. I stopped the other day and wouldn't restart. Left it 5 mins and it started but soon dies off after a couple of minutes. Once it dies there's no starting it but leave it 5 mins a
    nd it starts. It sounds like it's running out of fuel.
    So far changed plug, checked reeds/inlet manifold, cleaned carb, fitted manual choke,checked exhaust, took filler cap off. There is always a spark even when it won't start and there's fuel in the bowl also.
    Plenty of petrol getting to carb also.
    Any suggestions would be appreciated
    thanks
    bookster
    ontario
    get a new sparkplug. remove and clean both brass jets in the carb with a pokey. then you should be ok.
    Sep 2017
    Uk
    Update on this in case it helps anyone. It was the stator.
    Lesson learnt. Don't trust you have a spark unless you have a proper spark tester.
  1. X reg Scarabeo 50 4t - Cut out - No spark
    By Mgriff1887 in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 08-29-2014, 12:30 PM
  2. I made a video on how to add 2 stroke oil to an SR 50 to help out the newbies!
    By Kronicl in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 05-24-2014, 04:18 PM
  3. 2009 sr 50 cuts out
    By scaryjerry in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 01-09-2012, 06:41 PM
  4. possible 01 sr 50 ditech part out
    By Kneppys01 in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 08-29-2010, 01:53 PM
  5. My 2007 Sr 50 R Keeps Trying To Cut Out...
    By jonnyandrews in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 10-05-2007, 06:18 PM
