Results 1 to 4 of 4
Thread: sheared Crankshaft
    Jul 2010
    Jersey CI
    sheared Crankshaft
    Hi all,
    had a bad vibration yesterday whilst riding my SR 50 then no drive at all I took it as it must be the belt that's gone.
    Took off the Transmission cover today to find that the Crankshaft has sheared off : (
    Is this a complicated job to carry out and replace, I have manged to find a replacement on Crankshaft Ebay.
    Carpenter by trade but do feel quite confident stripping and rebuilding engine parts and have done so in the past to a : )
    Also what in your opinions would cause this to happen in the first place.
    many thanks, Andy
    ontario
    it looks like bad luck / i see the metal is flawed a bit. perhaps just that or maybe it was over torqued alot too.
    crankshaft are about 100 dollars for a motoforce crank. the topperf are nice too but they are atleast 150 dollars.
    crank bearings and seals maybe 50 dollars.
    try racingplanet for free shipping.
    i would get the airsal sport 70cc cylinder kit that uses the stock head. it will complete your scoot the way the factory intended. your machine needs nothing else.
    a marine shop or atv shop could have it rebuilt or send it up here for premium scoot tuning.
    May 2013
    Jersey Channel islands
    Hi sublunacy, thanks for you reply and advise, being over torqued makes good sense know that you mention it, i will try the sites you have suggested and then see if I can buy local in the UK
    many thanks, Andy
    ontario
    racingplanet.uk
    maybe SIP also
  1. Crankshaft recommendations
    By Joseph Pagan in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 07-03-2003, 02:55 AM
  2. Crankshafts for different models
    By RSVV60 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-30-2003, 12:07 PM
  3. Crankshaft
    By MotorHispania RX in forum RS50 Technical
    Last Post: 06-12-2003, 09:36 AM
  4. Replies: 1
    Last Post: 05-02-2003, 08:44 AM
  5. crankshaft locking pin
    By gemmell in forum Pegaso 650 Cube and IE
    Last Post: 02-26-2003, 09:38 AM
