Page 1 of 9 123 ... LastLast
Results 1 to 15 of 127
Thread: PatEF; the "Ef" for efficiency
    Apr 2014
    Athens Greece
    Hello all.
    PatEf
    In Fig. 1 a V-belt CVT is shown at a short transmission ratio (drive shaft: 1, drive pulley: 2, driven shaft: 3, driven pulley: 4, V-belt: 5).
    The torque M provided by the drive shaft 1 loads the V-belt by a force F=M/R2, wherein R2 is the radius at which the V-belt runs on the drive pulley 2.
    In order to avoid "belt slippage" in the drive pulley, a minimum clamping of the V-belt between the two conical halves of the drive pulley 2 is required.
    The same for the rear pulley: a minimum clamping is required, otherwise the pulley cannot apply the required force on the V-belt.
    In Fig. 2 the transmission ratio (defined as the ratio of the angular velocity of the driven pulley 4 to the angular velocity of the drive pulley 2) is long, about double than in Fig. 1.
    With the same torque M provided by the drive shaft 1, the substantially bigger radius R2' the V-belt runs on the drive pulley 2 reduces substantially the force F' loading the V-belt (F'/F=R2/R2') and proportionally the required clamping of the belt between the two conical halves of the drive pulley 2, and similarly it reduces proportionally the required clamping of the V-belt between the two conical halves of the driven pulley 4.
    However, as shown in the following drawing, the driven pulley spring of a conventional CVT is heavily over-compressed at the longer transmission ratios.
    While the efficiency (i.e. the ratio of the output power to the input power) of a conventional V-belt CVT peaks, at the shorter transmission ratios and the heavier loads, even above 95%, the efficiency drops well below 85% at the longer transmission ratios (overdrive) and the lighter loads.
    The low efficiency of the conventional V-belt CVT at the long transmission ratios comes from its architecture according which: a variator (or governor) at the drive pulley pushes its two halves close to each other, while a spring in the driven pulley is resisting and is forcing the two halves of the drive pulley away from each other.
    And here is the principle according which the PatEf operates:
    In Fig. 3 as the spring is more compressed, the force (FS, FL) it applies along its direction increases: FL>FS (the L stands for longer ratios, the S stands for shorter ratios).
    Analyzing the total force FL in an axial component force FLA parallel to the rotation axis 3A of the driven shaft 3 (the A in the FLA stands for axial) and in a perpendicular component force FLP on a plane perpendicular to the rotations axis 3A (the P in the FLP stands for perpendicular), and similarly for the FS which is analyzed in an axial component force FSA (parallel to the rotation axis 3A) and in a perpendicular component force FSP (on a plane perpendicular (normal) to the rotation axis 3A), despite the increase of the total force the spring applies at the longer ratios (because it is further compressed), the axial component of the force can reduce substantially at the longer transmission ratios (and proportionally can reduce the clamping of the V-belt), as the following plot shows:
    The arrangement of the springs is such that, while for higher and higher transmission ratios the springs are more and more compressed (providing a stronger and stronger force), the axial forces the springs apply on the two halves of the driven pulley (and the clamping of the V-belt these forces cause) is reduced.
    The above plot shows the "spring caused clamping" versus the distance between the two halves of the driven pulley for a conventional CVT and for a CVT having the PatEf (to be noted: at 0mm distance, the two halves are at the closest to each other position, which means the V-belt is running at the maximum diameter in the driven pulley).
    The above drawing shows the arrangement of a spring (actually of the axis of a spring) of the PatEf.
    The relaxed length of the spring (i.e. the length of the spring when it is unloaded) is L, and its projection on a horizontal axis has constant length D due to its arrangement.
    The axis of the spring has an inclination f relative to the rotation axis of the driven pulley (the rotation axis of the driven pulley is not shown, but it is parallel to the dashed-dot lines of Fig 31).
    The total force provided by the spring is Ft along the spring "axis", with:
    Ft=(L-(D/sin(f)))*k, wherein k is the stiffness of the spring.
    The axial component of the Ft is Fa, with:
    Fa=(L*cos(f)-(D/tan(f)))*k
    In the following plot it is shown the resulting axial force versus the spring inclination angle of the arrangement in the above drawing, for springs having various lengths.
    For the specific plot (but not obligatory) the stiffness k of each spring is taken reverse proportional to its length, which means constant k*L (to make springs of constant k*L one could use the same wire, the same coil diameter and the same pitch).
    Following the curve "L/D=2.5", one can see that the resulting axial force is zero until f=23.5 degrees (relaxed spring, asin(1/2.5)=23.5 degrees). Then the spring is progressively compressed.
    Until f=48 degrees the axial force increases with the compression of the spring (but not linearly).
    After the 48 degrees (at which the curve "L/D=2.5" maximizes), while the further increase of the angle f of the spring axis causes the further compression of the spring (because its effective length reduces), the resulting axial force reduces.
    From 60 to 90 degrees (at 90 degrees the resulting axial force gets zero) the drop of the axial force varies, more or less, linearly with the angle f.
    For instance, designing the driven pulley and its springs so that at the shortest transmission ratio (i.e. completely closed driven pulley and V-belt runsing at the maximum diameter on the driven pulley) the spring inclination to be f=53 degrees, and at the longest transmission ratio (i.e. completely open driven pulley and V-belt running at the minimum diameter on the driven pulley) the spring inclination to be f=75 degrees ("Axail force vs Spring inclination angle" plot), the resulting axial force (and the clamping it causes on the V-belt) reduces progressively and substantially as the transmission ratio increases.
    The resulting axial force (and the clamping it causes) at the longest transmission ratio is nearly 50% of what it is at the shortest transmission ratio.
    The 50% reduction of the clamping force at the longest transmission ratio fits well with what the Figs. 1 and 2 show.
    Practically:
    If the driven pulley of a scooter CVT is modified to PatEf, the ramps and the roller weights of the variator have also to be modified to fit with the substantially different clamping of the V-belt along the operating range.
    After the modification, the scooter (or vehicle in general):
    will be greener / more fuel efficient (a part of the fuel previously burnt to provide energy consumed in the CVT as friction, is saved),
    the scooter will have higher top speed,
    the CVT will run substantially colder and will need less energy for cooling / ventilation,
    the V-belt will last far longer (because it avoids running under extreme over-clamping).
    The mechanism fits also with bicycles having a V-belt CVT for the transmission from the pedals to the rear wheel (as in the GB 2,526,675 patent (PatBox CVT), for instance).
    The reduction of the over-clamping (and of the associated friction loss) is more significant in a bicycle because of the small available human power.
    The simplicity is among the characteristics of the PatEf.
    The saving of fuel and of power are also characteristics of the PatEf.
    The "automatic operation" is also a characteristic of the PatEf: after the assembly of the driven pulley, the reduction of the clamping force is realized automatically without external parts or control systems.
    According the previous:
    With the PatEf the mileage of a conventional middle size scooter can be improved more than 10% at typical highway cruising (say, 100Km/h (62mph) wherein the engine runs at medium load and wherein, according the above plot, the CVT runs already at (or near) its longest transmission ratio, which means the V-belt, in case without the PatEf, runs under extreme over-clamping (see the "efficiency vs over-clamping" plot, third image from top in this web page).
    With some three times lighter V-belt clamping, the expected durability of the V-belt gets several times longer.
    With the PatEf the scooter can also accelerate faster because a part of the energy previously consumed on the V-belt and on the pulleys, now accelerates the scooter, reducing at the same time the V-belt wear.
    With the PatEf the scooter can also achieve a higher top speed. Because at the maximum speed the CVT cannot help running at its longest transmission ratio wherein the over-clamping of the V-belt consumes (in friction and belt wear) a part of the power provided by the engine; with the PatEf, this power part is utilized: it is pushing the scooter forwards, improving at the same time the durability of the V-belt .
    Thoughts ?
    Manolis Pattakos
    Oct 2009
    No idea
    Clearwater, Fl
    Getting better! As long as slippage at high speed does not become an issue. Every 10 mph increase in speed once wind drag becomes an issue requires a substantial increase in power to the drive wheel and higher clamping force on the drive sheave to maintain it.
    Feb 2009
    Quote Originally Posted by redratbike View Post
    No idea
    Bwahahahaaaaaa.......here we go....again....
    Perfect spam.
    It's the hook that some just can't resist jumping on.....
    Same old shit...different bucket.
    https://www.f1technical.net/forum/vi...966&start=2100
    Apr 2014
    Athens Greece
    Hello all.
    This plot:
    simply says that your scooters at highway cruising are squeezing their V-belts several times harder than what is really necessary for avoiding belt slippage (differently speaking: with the current squeezing of the V-belt (belt clamping) your scooter CVT can transmit, without belt slippage, several times more power).
    This means poor transmission efficiency, poor mileage and high wear rate of the V-belt (the energy lost in friction heats / wears the V-belt).
    Provided the PatEf CVT can pass the maximum torque of the engine at the longest transmission ratio without belt slippage, it doesn’t matter what the wind drag is, or how steep an uphill is: the V-belt will not slip.
    Manolis Pattakos
    apriliaforum expert ledwrist's Avatar
    Jul 2008
    30°34′35″N 97°52′15″W
    Check this out instead of a CVT:
    http://www.fallbrooktech.com/
    Apr 2014
    Athens Greece
    Quote Originally Posted by ledwrist View Post
    Hello Ledwrist.
    Your link is about the NuVinci CVT:
    which is also a CVT.
    Quote from http://www.triketech.com/Drivetrain/n360.html :
    The chart gives a pretty accurate snapshot of efficiency levels found in the N360 (the NuVinci), Internal Gear Hubs (IGH), and a 10 speed derailleur for comparative purposes. No two test dynos ever give the same results on the same parts so take it with a grain of salt.
    What's important to consider is how often will you be riding at either end of an extreme of the range? Chances are over 50% of your pedaling is done at a ratio of .08 ~ 1.2. Contrary to what most folks claim, the N360 is pretty efficient in that range; more efficient then the typical IGH.
    Derailleurs are the most efficient however as sprockets get smaller and chainline moves off center it causes erratic changes in the efficiencies for each gear.
    IGH's suffer from drag as each gear is still meshing, just not engaged to the output shaft. More gears is more meshing losses. Ground gears can slightly reduce friction but comes at considerable cost.
    End of Quote
    The mechanism of the Nuvinci CVT is not for significant power, like, say, the power provided by a 125cc 4-stroke engine.
    Nor for the revs a CVT for a scooter is to run (say, 10,000rpmin for the drive shaft).
    As for using it in a bicycle, its cost is well above the cost of the rest bicycle.
    Compare the NuVinci in a bicycle with the PatCVT in a bicycle (more at http://www.pattakon.com/pattakonPatCVT.htm ) :
    with the PatCVT having in the rear pulley the PatEf (more at http://www.pattakon.com/pattakonPatEf.htm ) :
    Or compare the NuVinci on a bicycle with the PatBox CVT on a bicycle (more at http://www.pattakon.com/pattakonPatBox.htm ) :
    with the PatBox having in the rear pulley the PatEf (more at http://www.pattakon.com/pattakonPatEf.htm ) :
    Manolis Pattakos
    apriliaforum expert WadeS02's Avatar
    Sep 2005
    Minnesota
    A better, more efficient CVT would benefit the snowmobile industry. Those guys have been tweaking CVT's for decades now.
    I don't care about my apathy.
    Jun 2009
    Saint Petersburg, Florida
    motorcycles have clutches, gear shifters, and transmissions
    nuclear power by day, aprilias by day off
    RS250 Challenge - upstairs artwork in the house - The actual bike from Peter Egan's " A Pure Racebike " leanings article in Cycle World
    RS250 Challenge - carbon everywhere!
    RS250 Challenge - dad's fathers day present
    RMV125 - RS50 with CR125R motor - "it would never work," they said... "it would be horrible and pointless," they claimed...
    RMV125 - RS50 with CR125R motor - built for my dad after he rode mine!
    RS50 - in pieces, future RMV125?
    Genuine Buddy 50 - the scoot
    Feb 2009
    Bwahahahaaaa......
    Have you guys not realised the op is trolling here?
    Apr 2014
    Athens Greece
    Hello WadeSO2
    The snowmobile CVT’s and the scooter CVT’s are quite similar in operation.
    The PatEf can release, both of them, from a lot of friction and wear.
    The energy not lost in friction is used to accelerate faster the vehicle and to increase the final speed.
    With the PatEf the fuel previously consumed to make the energy that is lost as friction into the CVT, is saved increasing the mileage of the vehicle (snowmobile or scooter).
    With the PatEf, the reduced belt clamping (and the reduced belt wear it causes) extends substantially the life of the V-belt.
    Manolis Pattakos
    Apr 2014
    Athens Greece
    Hello Mattology
    You write:
    "motorcycles have clutches, gear shifters, and transmissions"
    There is a “hybrid”, between the scooters and motorcycles.
    It is the Aprilia Mana 850 equiped with the SECVT (Suzuki Electronically controlled CVT):
    As the Aprilia Mana 850 bridges the gap between the scooters and the motorcycles,
    similarly the PatEf bridges the “efficiency gap” between the conventional gearboxes and the CVT’s, brinking the two world closer to each other.
    Manolis Pattakos
    Apr 2014
    Athens Greece
    Hello all.
    The following animation (added to the http://www.pattakon.com/pattakonPatEf.htm web page) may help:
    The more the springs are compressed, the less the total force on the upper sphere.
    Manolis Pattakos
    Clearwater, Fl
    What a nightmare that would be to service though if the springs tended to come off their pivots while riding.
    One could end up with a fussy system that would make the bike it was installed in highly unreliable due to the complexity of the springs and balls.
    Apr 2014
    Athens Greece
    Hello all.
    While the springs in the PatEf are similar with the poppet valve springs, their “life” is by far easier because they compress and extend at a way slower rhythm.
    In a minute, each valve spring of the Aprilia SportCity 250cc is fully extended and then is fully compressed for 4,000 times (8,000rpm of the 4-stroke engine).
    Think how many times in a minute the transmission ratio of your CVT goes from the shortest to the longest ratio, and then back to the shortest ratio.
    Two times?
    Three times?
    This is more than 1,000 times slower than the rhythm the poppet valve springs compress and extend.
    Can the springs of the PatEf come off their pivots?
    They can’t.
    The color flat surfaces in the following drawing:
    are whereon the springs abut “radially”.
    These flat surfaces receive the centrifugal forces generated by the eccentric rotation of the PatEf springs, and keep safely the springs “trapped” in their supports.
    Even if the specific way the PatEf springs are supported is questionable (you can think many other ways), what is not questionable is the reduction of the power loss inside the CVT and the reduction of the V-belt wear the PatEf offers.
    Think cruising with your scooter on the highway at 100Km/h (62mph) with, necessarily, the longest transmission ratio in the CVT.
    As it is now your CVT, the squeezing (the clamping) the pulleys apply onto the V-belt is unnecessarily high (with the same squeezing you can transmit, without belt slippage, a few times more power), and this high squeezing causes friction (i.e. power loss, which translates into lower mileage) and belt wear.
    With more than 10% higher mileage at highway cruising and more than double V-belt durability, calculate the saving with the PatEf on the running and on the maintenance cost of your scooters.
    Manolis Pattakos
  1. Stick with the RS or go for a restricted 400!??
    By technoandy in forum RS125 Euro-archive
    Last Post: 05-23-2003, 09:12 AM
  2. Giving up on the RS, traded it for a CBR250RR
    By Tokyo Rider in forum RS125 Euro-archive
    Last Post: 05-21-2003, 02:29 AM
  3. The coolest Sprockets in the World...and now for Aprilia
    By micah apriliaforum com in forum SL1000 Falco Forum (all years)
    Last Post: 12-29-2002, 08:14 PM
