Results 1 to 9 of 9
Thread: ATC/AWC Question
    Mississauga, Ontario
    ATC/AWC Question
    Recently Purchased 2017 Aprilia Tuono V4 1100 RR, almost 1000 KM on it, at some point my Traction Control and Wheelie control got switched off. I have not been able to turn back on. I'm not quite sure how to turn back on. Is it just me being new or is there possibly an issue.?
    apriliaforum prov-nov DamianW's Avatar
    May 2017
    Auckland
    ATC/AWC Question
    Just use the + and - silver switches on the left hand bar to adjust ATC on the fly. The + switch is near the horn and the - switch is on the clutch lever side of the bar.
    Current bikes:
    2017 Aprilia Tuono Factory
    2006 Suzuki GSX-R600 (trackbike)
    I have tried this several times with no luck, bike with engine off, bike with engine on. Long press/short press of the + and - switch. I figured them both being disabled was an issue after trying this as i'm not even able to select them in the menu anymore.
    apriliaforum prov-nov Promatt's Avatar
    Toronto
    How long did you keep + pressed? It takes a few seconds. Did you adjust the clutch perch position and now the lever is hitting the - ? Press with the bike in N to be sure.
    ok thanks Promatt, I'll give that a try
    apriliaforum Junkie Blackfin's Avatar
    Jul 2016
    Ontario, Canada
    If necessary you can use the little hat-switch on the left to navigate the MENU to APRC settings where you can set the ATC and AWC etc.
    Keeping mind that AWC is automatically turned off if ATC is turned off.
    apriliaforum expert chrman's Avatar
    Mar 2004
    Albany, NY
    You disabled traction control inadvertently just like I did. Just hold down the lower '+' button for a few seconds until ATC 1 comes back.
    -Chris
    '17 Aprilia Tuono V4 Factory
    '15 BMW R nineT (for sale)
    '01 Suzuki GSXR1000 track bike
    '10 KTM 300 XC-W
    '13 KTM 150 XC
    Gone but never forgotten: '02 Mille, '07 SXV 5.5, '01 Aprilia RS250, '06 Ducati Monster S2R
    Aug 2017
    Canberra, Aus
    As above, holding it down (+ or -) will turn it on and off. Quick taps for incremental changes.
  1. ATC & AWC setting for wheelies & ride
    By Zdipi in forum 2010-2017 RSV4 - All Variants
    Last Post: 09-30-2017, 02:59 PM
  2. 1100 RR ATC on 5 AWC off engine cuts on hard acceleration
    By kinjo695 in forum 2012-2017 Tuono V4 - All Variants
    Last Post: 11-27-2016, 05:49 PM
  3. atc + awc vs alc
    By jcbarnard in forum 2012-2017 Tuono V4 - All Variants
    Last Post: 04-17-2015, 08:55 PM
  4. AWC and ATC
    By phenixdragon in forum 2010-2017 RSV4 - All Variants
    Last Post: 04-27-2013, 11:50 AM
  5. Question about MotoGP
    By RSVR 02 in forum Professional Racing Discussion
    Last Post: 04-24-2003, 01:11 PM
