Results 1 to 6 of 6
Thread: Burnt cables tuono 2003
    apriliaforum Junkie john in sweden's Avatar
    Sweden
    Hi ! I just discovered some really bad cables at right rear side of my bike,
    It seams out like the former owner have played with some stuff,
    Does anyone recognise these burnt cables ?
    It it for the tilt sensor ?
    If it is it explains why I can't find it at my bike,
    I understand I have to order a new harnes and fix it soon as possible,
    But first I would like to know what they are for .
    Best regards from Sweden
    Link to my problem:
    https://www.dropbox.com/s/rfjb3bc5st...55.32.jpg?dl=0
    My friends call me Kieth but you can call me John.
    (citat Kieth Moon)
    Oct 2009
    Be more people looking in the tuono section repost there
    I don't recognise the colour code of the wires to assist
    But you should have 3 relays in a row and the tilt switch is one of those
    Jun 2009
    oldham uk and soon gibraltar
    Looks like a 12v supply from battary for a trickle charger where does the other end of the wires go? Is there a 12v supply there ( switched on or switched off) if your after a wireing loom I have one that came with a lot of bits off a tuono raceing it's not been chopped into and has been boxed up make me a offer as I sold the tuono 4 years ago
    Sweden
    yes maybe im intrested of your harness,,
    i will controll the harness more first at my bike,,
    there is som harnes at ebay so if you are intrested of prices like that it is ok for me.
    best regards from sweden.
    Quote Originally Posted by haga lout View Post
    (citat Kieth Moon)
    Scottsdale, AZ
    Quote Originally Posted by john in sweden View Post
    Link to my problem:
    Those are the positive and earth wires in the harness that should be connected to the voltage regulator's earth and DC+ connections. High resistance has caused enough heat to melt the insulation and ruin the wires. All of that damage has to be cut out and replaced. I also see a cut in the insulation of one of the AC yellow wires. This is what happens when a butcher tries to remove the charging system brown and white connectors.
    Oct 2009
    Time to buy something like this and swap part of the loom out
    https://m.ebay.co.uk/itm/APRILIA-RSV...%257Ciid%253A3
  1. Wtb tuono 2003 ohlins damper & a/m rear shock
    By klavdy in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 02-18-2011, 06:48 PM
  2. I need Tuono ( 2003 - ) components !!!
    By Óriás in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 04-21-2010, 11:00 AM
  3. Tuono 2003 for sale (Edinburgh UK)
    By rsvandy in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 01-27-2010, 02:44 PM
  4. Tuono 2003
    By arl in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 01-31-2007, 12:13 AM
  5. de-restrict RS50 tuono 2003
    By Steffman in forum RS50 Technical
    Last Post: 02-16-2006, 04:40 PM
