Page 2 of 9 FirstFirst 1234 ... LastLast
Results 16 to 30 of 124
Thread: Heated Grips for 2017 Tuono
    apriliaforum Junkie DarK_SpY's Avatar
    Sep 2015
    Canada
    Quote Originally Posted by ADPrilia View Post
    Hi All,
    Has anyone fitted heated grips to the 2017 Tuono. As you know, Aprilia doesn't make them for the tuono. Dealer tried to fit oxford grips but because of the cruise control on the left he said they wouldn't fit properly.
    Andrew
    cruise control doesnt interfere at all with the oxford, i have it on my 2016 and a friend on his 2017 and the grip is the same
    Auckland, New Zealand
    Quote Originally Posted by Markey View Post
    Any more of you chaps fitted any heated grips to the 17 ?
    Liking the look of these Koso ones if I'm honest
    Yep they fit the 2017 bike. I mentioned in back up in post #9
    Couple of things though with the 2015/16 bikes and the 2017.
    The grips are 5mm too long. Just cut the end off once installed. Any more than 10mm and you might cut the wires. I turned mine on to feel the heat from the wires to determine where the wires were.
    On the left hand grip you need to cut down the plastic 'extending/sleeve bit that holds and houses the traction control +/- buttons. It extends 10-15mm along the left handlebar and just needs to be cut off with a hacksaw. 5 min job. It will never be seen and serves no purpose.
    On the 2017 bike the same thing applies. But also (as mentioned in previous posts) on the throttle grip, the plastic housing for the grip is about 1 mm wider than the 2015/16 bikes. So it will be hard to get some heated grips slid over the throttle grip sleeve. On some brands of heated grip you will need to hone out the heated grip hole a tiny bit to get it to slide over. We used a curved edge rasp/file. Took 10 min to hone it out.
    Or... use the slightly bigger grips. The new Daytona worked for 2017 bike (and 2015/16). Oxford didnt fit.
    ScottyDog
    In The Garage
    1. Tuono V4 1100 RF, stock gearing, Austin Racing GP2R pipe, Race ECU, heated grips, CRG Bar End mirrors, Hepco-Becker sports Rack with Givi Top box when touring, Intercom to both give and receive abuse, Nitrous kit, super charger, shitty Chinese folding levers & a flashy sticker that makes me faster...
    2. Maserati Granturismo S 4.7L MC F1 Gearbox
    3. Land Rover Discovery Sport
    apriliaforum expert Markey's Avatar
    Aug 2012
    Swansea UK
    Ok great
    What about the Yamaha ones then ?
    These are more ready available here in the UK whereas the Koso's need to be shipped across the pond
    apriliaforum expert PRC001's Avatar
    Feb 2013
    Cape Town, South Africa
    All I can say is that the Yamaha ones are great... really neat fit and work very well to point that I very rarely use the highest setting as they're so damn hot
    Don't know about fitment to a '17 but friends have them on all sorts of bikes.
    2015 Tuono V4 1100 Factory
    Brembo RCS19 MC, Akrapovic Exhaust, GRT ECU, DNA filter, Lightech levers, rear-sets & chain adjusters, Evotech tail-tidy, Evotech fork & swingarm sliders, Cox Racing Rad Guard & Aprilia Factory Forged Alloys.
    2012 Tuono V4 APRC Fast
    Black.... Sold
    Yamaha MT-10 SP... sold, boring Jap appliance.
    Aug 2012
    Swansea UK
    Just ordered the Yam ones so il post back when IF they fit
    apriliaforum Member Fire_2's Avatar
    Aug 2015
    London, England
    My buddy has the Yamaha grips and thinks the anit all that sure they look good with inbuilt controler but they don't get that hot?
    apriliaforum Junkie bigrog's Avatar
    Apr 2017
    Malta
    Quote Originally Posted by PRC001 View Post
    Can you turn them off without having to cycle the temperatures, and do they remember the last setting when turned on again? Also can you remember if they were built on rigid plastic tube centres?
    I love the easy looking installation loom.
    The Third Law of Human Dynamics: For every opportunity to communicate there is an equal and opposite opportunity to misunderstand
    Apr 2017
    Malta
    Quote Originally Posted by Fire_2 View Post
    Did he program them correctly, they seem to have three upper power levels 8 -18W (scooter), 8 - 20W (small to medium bike), and 8 - 22W (larger bikes) which need to be pre programmed in the controller? Webbikeworld calculated that the Koso was 39watts on maximum, so quite a bit hotter.
    Apr 2017
    Malta
    This is the specification drawing for the Koso Apollo. How does that compare with the throttle side diameter on the 2017 Tuono? Also what about the lengths?
    Unfortunately I don't get to see mine until next week
    I forgot to mention that I needed to cut off about 5 mm of rubber from the end of the hot grips so that they fit onto the tuono. I'll edit my earlier post.
    ScottyDog
    In The Garage
    Feb 2013
    Quote Originally Posted by bigrog View Post
    Not that sophisticated I'm afraid and really doesn't bother me about an extra couple of button clicks. They do have an auto-off if not wired via the ignition, which mine are. I like them because they simple, neat and effective.
    Black.... Sold
    Aug 2012
    Swansea UK
    Any pick up points around the headlight for + & - ?
    Or has everyone run them back to the battery ?
    Battery. Plus a relay switch connected to my tail light
    ScottyDog
    In The Garage
    Sep 2017
    Australia
    Heated gloves are better imo because the part of the hand that gets cold is the top of the hand as it is exposed to the wind, but heated grips heat the palms of the hand.
    I got these bad boys, keep your hands nice and toasty on 3 different settings:
    https://www.amawarehouse.com.au/five...er-gloves.html
    Aug 2015
    London, England
    Ok so today finally fitted the new V8i oxford heated grips!
    works perfect! very happy after a little trimming to sit closer to the ATC switch's
    both oem grips came off complete with just an airline and a little pull, also I used better glue then the supplied.
  1. Replies: 0
    Last Post: 01-14-2014, 02:16 PM
  2. [Capo] Frame and fork protectors and OEM heated grips for Caponord 1200 - Australia
    By fredaroony in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 01-14-2014, 02:15 PM
  3. Best heated grip for our beloved
    By BigK in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 03-06-2013, 07:31 AM
  4. Heated grips for $12.50!
    By apriliajohn in forum SL1000 Falco Forum (all years)
    Last Post: 04-10-2012, 09:32 AM
  5. Fitting heated grips to my Tuono
    By BikerBen in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 11-08-2010, 01:18 PM
