Results 1 to 14 of 14
Thread: Has anyone tried the "Rapid Bike Evo" fuel trim set up yet on either the TP or ,
    Dec 2012
    Arizona
    Has anyone tried the "Rapid Bike Evo" fuel trim set up yet on either the TP or rally
    Sep 2013
    Shropshire UK
    Quote Originally Posted by andyf View Post
    I have it in a box waiting to fit. It's about number 3 on list of things to do so I may be some time.
    The RB Evo is probably the most comprehensive solution outside of an actual re-flash of the original ECU. Continually adjusts the fuelling on the fly over the full rpm range. Can auto adapt to exhaust and airbox mods. You can transfer the module to another bike by purchasing the necessary wiring harness. You can buy a 'bypass' connector to easily bypass the module for service /emissions requirements. If you want you can hook up to a laptop and see / modify the map.
    They sent me a harness for a Dorsoduro, which is similar but only has one O2 sensor - I had the right one sent to me within 2 weeks. The wiring harness looks to be high quality. Reasonable installation instructions with colour pictures of the connections. They do say mount the module on top of the battery - not possible, fortunately the wires look long enough the locate it under the pillion seat.
    Dec 2012
    Arizona
    Quote Originally Posted by RSTman View Post
    Thank you, Andy
    May 2016
    Pennsylvania, US
    Looks like a nice piece of kit, despite a bit of questionable hype in the description.
    However, I've got one question:
    What problem are trying to solve through the installation of the RB Evo?
    Sep 2013
    Shropshire UK
    Quote Originally Posted by rmsppu View Post
    Poor low speed fueling. Doesn't seem to affect all bikes, Rally seems OK. My 2013 bike could be better, especially poor when new. Better now with miles and exhaust optimiser (standard on Rally) but still room for improvement. Any power gain will be a bonus, more power is not the primary objective.
    If you're happy with the way your bike fuels then I wouldn't bother with RB or Fatducs etc.
    Aug 2015
    Gilbert, Arizona (USA)
    Just put one on my Dorsoduro. http://www.apriliaforum.com/forums/s...RBEVO-032A-EX)
    I know it's a different bike, but thought the thread might be interesting to you.
    Sep 2013
    Shropshire UK
    Quote Originally Posted by rule62 View Post
    Thanks for the link. My results with the RB EVO / Caponord are similar to yours and posted here.
    http://www.apriliaforum.com/forums/s...rapid+bike+evo
    Well worth the money, for me anyway.
    Sep 2017
    Far Eastern Pacific
    Timeless Tuner Wisdom
    In the old days of carbureted engines expert tuners told me not to bother with rejetting a brand new bike, because it's very likely that tune will be wrong once the engine beds in. It's the tightness of new motors which makes them feel less responsive and poorly carbureted.
    My new Capo Rally feels so much better with increasing miles! Its Touring ECU map was originally too sluggish and laggy but that's not the case at all now, it feels great!
    Sep 2013
    Shropshire UK
    Quote Originally Posted by Ricardo J View Post
    Current emissions regs are mainly to blame. Only very recently do manufacturers seem to have overcome the issues. The last three bikes I've owned, manufactured between 2009 and 2013 all had fueling issues. Non of the previous 30 or so from 1972 to 2004 did. My Caponord TP did improve with miles but still far from perfect. RB evo has it pretty much solved.
    FWIW I think the Rally has different camshafts to the TP. That might be the main reason why Rally owners don't seem to have the poor low speed fueling issues.
    Sep 2017
    Far Eastern Pacific
    Could Be
    Whether or not Aprilia has fiddled with the Rally's engine internals I don't know, but my Rally's running manners improve with every ride. Idling, throttle response, low rpms, roll-ons, smoothness...everything gets better as this motor gets some mileage.
    Sep 2017
    Far Eastern Pacific
    RST, I spent some time comparing the TP and Rally parts diagrams here on AF1, yes the camshaft part numbers are different between these models, at least in the US of A.
    apriliaforum Member andydj31's Avatar
    Jun 2005
    near Noale!!
    And a different Ecu map too...
    P.S. sorry for my bad English!!
    Aprilia Caponord 1200 Rosso Formula
    Aprilia Rst Futura '02
    Aprilia Caponord RR '04 "Gundam" o "Biscottone".
    Aprilia Pegaso Cube 650 '01 "La piccola".
    Jul 2016
    Montrťal, Canada
    Hi,
    I have waiting in a box the entry level of the Rapid Bike. It is called the Rapid Bike Easy (instead of Evo). It is not available in US webstore so I had to order it from Europe.
    It is a less complicated solution than the Evo and also much less expensive, does not require a laptop and software. It basically plugs on the Lambda sensors on the exhaust and then adjusts the fuel/air ratio. It is adjustable through dimmers on the module.
    It will be fine for a slip on exhaust and air filter. More mods than that I have been told that you would be better with the Evo.
    I will be fitting it during the winter as my bike is stored in the garage given the - 30 C outside. I will be able to give feedback only in the spring on how well it runs.
    http://www.dimsport.it/en/rapidbike/easy/
    2015 Caponord White TP
    Heated grips, Gel seat, Givi Screen, Aprilia Top Box, GPR Exhaust, ESE Healtech, DNA Stage 2 Filter, RapidBike Easy Module, RAM Phone mount
    Sep 2013
    Shropshire UK
    Quote Originally Posted by jimbertrand514 View Post
    Hi,
    You don't need a laptop or software for the EVO either, it's plug and play. You can however hook up a laptop and see the map data as I understand - if you want.
    DIFFERENT SOFTWARE PROFILES
    Rapid Bike technology includes a sophisticated software managing all main features of EVO and RACING modules for fine tuning operations, as well as the full range of accessories.
    The advanced software version include all the accessories required by the professional tuners, while the end-user version can be downloaded free of charge
  1. Has anyone tried the Wolfman Beta Bag on their Futura?
    By Papa in forum RST1000 Futura (all years)
    Last Post: 10-05-2005, 12:07 AM
  2. Has anyone tried the ART twin high level exhaust?
    By RSV_Ecosse in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 10-04-2005, 08:27 AM
  3. Has anyone tried the new "high performance" fuels?
    By molan in forum RST1000 Futura (all years)
    Last Post: 10-22-2004, 07:30 PM
  4. Has anyone tried something to temporary quiet down the exhaust?
    By RVZoo in forum General Motorcycle Talk
    Last Post: 06-29-2004, 03:38 PM
  5. Has anyone tried the MK PRO race clutch?
    By 98shaikh in forum RS50 Technical
    Last Post: 08-29-2003, 08:16 PM
