Results 1 to 2 of 2
Thread: 2014 aSr50 motard 4t hard cold starting
    Aug 2017
    New Brunswick, Canada
    My son's had the bike since new this year it developed an extreme cold starting issue. At +30c it takes multiple minutes to start. I assumed it was the electric choke so i got a new one, there is no change in starting still super hard. I also pulled the plug to check it seems to be a sparking fine. Fuel is also coming out when i crank it over i pulled off a line to check. Is there any other common things i should look for? Once warm it runs great, starts easy when shut off and started with in the next 20 to 30 minutes and has the power you would expect from a 50cc.
    Thanks for any advice/help.
    Jun 2013
    the carburetor is not adjusted right or some hole in it is clogged
    also try to start the bike with 1/4 throttle or full throttle when cold
  1. 2014 SR50 Motard 4T Fuel/emissions Issues?
    By Radixx in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 07-04-2014, 01:50 AM
  2. 2014 RS50 Motard 4T Fuel Issues?
    By Radixx in forum RS50 Technical
    Last Post: 06-11-2014, 12:33 PM
  3. hard to start from cold
    By smithster in forum RST1000 Futura (all years)
    Last Post: 11-17-2011, 04:08 AM
  4. rsv4 hard to start when cold.
    By btw in forum 2010-2018 RSV4 - All Variants
    Last Post: 04-06-2010, 01:58 PM
  5. Hard to start cold,but....
    By JohnG. in forum 1000cc f.a.q
    Last Post: 08-07-2007, 10:22 PM
