Page 1 of 4 123 ... LastLast
Results 1 to 15 of 46
Thread: Pulled the charcoal canister off my 17 RR....
    Jul 2017
    Northwest Indiana
    This weekend I was bored so I decided to pull the charcoal canister off of my 17 RR. Little bit of a pain but not bad. It actually helps my bike run about 5 degrees cooler on average and helps the fan do its job....I was amazed actually. Win Win!
    Jul 2017
    Chelsea, MA
    How much did it weigh?
    apriliaforum Junkie Blackfin's Avatar
    Jul 2016
    Ontario, Canada
    I've looked at my 17 Factory and often wondered if part of the reason the thing runs so hot in traffic is because of the placement of the canister on the left-side and the exhaust servo on the right side; both seem to effectively block airflow from the back-side of the rad.
    What steps were required to remove the thing?
    Jul 2017
    Northwest Indiana
    Quote Originally Posted by frenchwv View Post
    Not much.....maybe 6 ounces.....
    Jul 2017
    Northwest Indiana
    Quote Originally Posted by Blackfin View Post
    The servo on the right and the canister on the left, IMO, definitely play a part in the lack of cooling on this bike especially with the fans on. There is just nowhere for the air to go!
    Basic steps were the following:
    - Remove front and rear seat
    - Remove left tank side cover
    - Remove left front side panel
    - Unbolt canister holder assembly from frame
    - Cut ty-wraps holding canister to holder assembly
    - I cut the lines above the clamp on the canister
    - Remove canister and pop the clamp on the rear most vent hose on the gas tank and pull hose off the nipple
    - Curse, cuss and swear as you try and pull the vent line with the check valve out from the rear.
    - Put a bolt in the smaller line that was on the canister and clamp it or use a ty-wrap. Make sure the bolt fits snugly. route the line and secure with the wires that are there.
    - Remove the connectors from the canister holder and secure connectors neatly with the other wires in the area.
    - Cut vent line to appropriate length and re-install on tank vent nipple and route straight down with the fuel overflow vent. I routed it right behind the sprocket guard behind the sprocket cover (perfect place) and secured with a couple ty-wraps.
    - Cut the majority of the canister holder (I just used a hack saw) and leave the part that mounts under the frame bolts that says V4 on it and maybe a bit that goes around the frame (it will be self explanatory).
    - Put everything back together and enjoy a cooler running, non-tank pressurizing bike, lol.
    apriliaforum Junkie Great Scott's Avatar
    Jun 2015
    Fort Worth, TX
    When pulling the vent line out with the check valve, I'd recommend spraying some soapy water on the line for lubrication. It took no time at all when I did this on my 2016 MY.
    2016 Aprilia 1100 Tuono Factory
    "It is as impossible to withhold education from the receptive mind, as it is impossible to force it upon the unreasoning."
    Aug 2017
    GB
    Quote Originally Posted by CRFan1 View Post
    Hi, can this procedure be reversed? Is it just to save weight or was the cooler running thing part of the reason? thx
    Jul 2017
    Northwest Indiana
    Quote Originally Posted by Great Scott View Post
    That is actually a great idea. Thanks for the input!
    apriliaforum prov-nov YellowSF848's Avatar
    Jun 2017
    Leesburg, VA
    I'm thinking this is something I'm gonna have to do. My RR built up A LOT of hear the other day in traffic, enough that I began to worry about it..
    Sent from my ONEPLUS A3000 using Tapatalk
    Jul 2017
    Northwest Indiana
    Quote Originally Posted by Shift_R View Post
    It can be reversed but the way I cut the canister mount I would need to order a new one. I would never want to reverse it anyway, lol. The mod is mainly to prevent the current system from causing pressure build up in the tank when/if it malfunctions. The by product is you also get a slightly cooler running bike as well.
    Jul 2017
    Northwest Indiana
    Quote Originally Posted by YellowSF848 View Post
    Well it won't eliminate it completely but it helps....it is a mod that is meant to prevent pressure build up in the gas tank.
    Aug 2017
    GB
    Excellent! thank you.
    Jun 2017
    Leesburg, VA
    Yea, I know, I removed it off my streetfighter after they began have tank vacuum issues that Ducati refused to acknowledge.
    apriliaforum Member Catatafish's Avatar
    Apr 2017
    Memphis, TN USA
    It's also one less thing to get in your way during oil changes or hose work.
    May 2017
    Chicago, IL
    Great write-up... Thanks for sharing. I wish you took some pics as you were doing it (still v. helpful).
    Questions: any issues if I just cut hoses at the canister and remove it, without rerouting anything? I understand that I need to plug that one line you mentioned. Also, is the vent nipple on the left side of the tank? I'm ready to disconnect that thing from the tank ASAP, even before I get a chance to properly get rid of the canister... I've been meaning to do it for weeks, and your post really motivated me
  1. Pulled the slave cylinder off for cleaning - WHAT DID I DO?
    By motoed in forum RST1000 Futura (all years)
    Last Post: 01-08-2007, 06:40 AM
  2. I'm thinking the impossible....selling off my Mille
    By Chuck B in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-28-2005, 08:21 AM
  3. Pulling the rear tire off
    By Toddler in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 05-11-2005, 03:27 PM
  4. removal of the charcoal canister?
    By USA MEDIC in forum ETV1000 CapoNord (2001-2007)
    Last Post: 04-20-2005, 10:05 PM
  5. Can I pull the lighting coil from my flywheel?
    By maRRtin in forum RS50 Technical
    Last Post: 03-03-2005, 03:46 PM
