Results 1 to 7 of 7
Thread: 2009 SR 50 EFI connect comes up on the dash?
    Aug 2017
    Los Angeles
    Hi,
    I am sure you have answered all these questions in here before. But my dash has a light bulb that flashes and has a arrow that alternates sides. Then EFI pops up with a plug taken apart? I just replaced everything on the fuel system from tank to injector. The only code is a dash DSB code 5 x in the memo side?
    Aug 2017
    Los Angeles
    The dash code went away but the ECU code 14 came up on the memo side. Still have the EFI light bulb tho!!!
    Aug 2017
    Los Angeles
    Tried to load a video but it didn't work
    Aug 2017
    Los Angeles
    How do I load a video?
    Jenison, Michigan
    This is the carb section
    2009 SR 50 Factory
    Malossi 70cc BBK
    Malossi HPC Crankshaft
    Stage6 Waterpump Impeller
    Arrow Extreme Pipe
    Malossi VL 13
    Ecu De-restricted 2.8.0
    7 Gram Dr. Pulley Sliders
    Stage6 Soft Contra Spring
    Water Trap
    RS 24/10
    Stage6 260mm Front Brake
    Stage6 R/T Clutch Bell 460g
    Malossi Special Belt
    Malossi E5 Air Filter
    Stock Gears Installed
    Aug 2017
    Los Angeles
    Sorry
    Aug 2017
    Los Angeles
    Does anyone know how I could delete this? I put it up in the right place.
  1. 2009 SR 50 Factory Engine info?
    By blue rocket in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 07-03-2008, 07:45 AM
  2. 2003 Grey Coming up on 30,000 miles. Any advice?
    By mikesduc in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 09-28-2007, 11:02 AM
  3. oil can, come up on display
    By fredgreen in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 09-03-2007, 11:38 AM
  4. (SR 50 R 2005) Need help on spark plug and carb.
    By leobusti in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 03-12-2007, 07:34 AM
  5. Bike is coming up on 20K miles...
    By meeoch in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 01-26-2007, 12:06 AM
