Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
Thread: Click click click, or tick tick tick
    Sep 2017
    Buenos Aires
    Hi drogat!
    Very good your explanation ! a question can I take the especial bolt off without remove the gear? I mean without disassembly head cover , just from the side of the cylinder ?
    Jul 2017
    Sarasota
    I was just at the shop and it does not look like a diy job. You have to remove the clutch, timing chain ect.
    Mar 2017
    British Columbia
    It looks like the special screw could be removed but would the cam gear, washers and chain fall into the engine case? I am dying to tear into this to see if i have the dreaded bushing gone bad.
    Jul 2017
    Sarasota
    The noise is real loud. My shop is having a hard time getting the timing back. Should be done tomorrow
    Dec 2011
    Arizona
    Quote Originally Posted by abnknows View Post
    One indicator of a bad bushing is a mis-alignment of the anti backlash teeth on the cam gear. This can be seen by removing the cam cover and using a small mirror to see if the two gears are or not aligned. If the teeth on the gears are closely aligned things should be OK. If not there is slop in the bushing. And the cam timing is retarded. Big tear down required, but the correct parts are good to go. I have 23000 miles on mine since it was fixed.
    Sent from my SM-G900P using Tapatalk
    Jul 2017
    Sarasota
    I finally got mine back a few weeks ago. They showed me the bushing and special nut. It didn't look too bad. I hope that the major issues are in the past.
    Mar 2017
    British Columbia
    The shop just told me they had a 750 shiver in and it had the same problem; intermediate shaft and gear worn out, low klms. Just for fun, i checked the part numbers and the shaft and gears are identical for the 750 and 1200 motor. So this problem has been around for a while.......
    Mar 2017
    British Columbia
    Update is my bike has been at the dealer for over a month now, waiting on parts. Engine top ends completely stripped and new cam bushings and intermediate shafts being replaced as well as water pump seal, ADD rear pump and control unit, fuel level sensor, did i forget anything?
    Jul 2017
    Sarasota
    It is funny that you mentioned that. My wp seal had to be replaced. Did you know you had an issue. I didn't.
    Mar 2017
    British Columbia
    No sign of it to me and i go over my bikes pretty close. They said they smelled coolant and pointed out a minor weep on the water pump.
    Nov 2017
    Uruguay
    iI needed 10 hours of work (made it int 4 days) to replace the front cylinder intermediary gear.
    the bike was 1000kms when it started with a small "valve like noise" but it was bigger and bigger, at 3000km I replaced it.
    Now I heared a small click from the rear cylinder but is far, far away from the louder noise comming from the fron one...I think I will replace the back gear in the next air filter cleaning...
    Mar 2017
    British Columbia
    No positive update from my dealer, parts still taking the slow boat from Italy. And at least i think i heard them right that they are doing the rear cylinder also. Really is disappointing that they pretty much admitted they are seeing more of these same parts self-destructing on the 1200 and 750, and yet no admission from distributor or factory or issuance of a TSB safety bulletin or recall. Not sure my shop is too pleased to be doing the major teardown and rebuild either, as even their super well trained and competent mechanic breaks out in beads of sweat on his brow at just the thought of another one of these jobs. I hope the factory labour guide is generous enough to cover all the time they are putting into this, thankfully under warranty.
    Nov 2017
    Uruguay
    snipermike, do you have the chance to take a picture from the gear, detailing the part number, before its drop inside the bike?
    Mar 2017
    British Columbia
    I will ask the service manager to do so. They have been pretty good about it since finally admitting the problem.
  1. Engine Tick/Tap/Click noise when warm
    By ooter in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 03-24-2015, 02:21 PM
  2. clicking and ticking sounds
    By 7Brothers in forum 2010-2018 RSV4 - All Variants
    Last Post: 10-05-2013, 06:01 PM
  3. Click/Tick During Braking
    By SilverFoxUno in forum 2008-2014 Mana 850 and Mana 850 GT-ABS
    Last Post: 09-23-2008, 04:39 PM
  4. Bike Wont start or tick, Can be bumped. Pissed Off
    By therefused in forum RS125 Euro-archive
    Last Post: 10-19-2006, 11:05 AM
