Results 1 to 15 of 29
Thread: Click click click, or tick tick tick
    Jul 2017
    Sarasota
    What is this noise on the stator side of the motor. The noise is pretty obnoxious. It feels like it is coming from above the stator cover. Are those injectors tucked in there?
    Jun 2016
    Seattle, Washington USA
    Good question. I'm curious about all the ticking from my motor too. Aprilia dealer told me it was normal characteristic of the motor design. It seems noisier than any bike I've owned. It's a bit nerve racking pulling into gas station and getting stares from other riders. My deaf, Harley riding 80 y/o uncle commented on the motor noise "must be solid lifters".
    apriliaforum Junkie Rockbyter's Avatar
    Aug 2015
    Co. Durham, England.
    Does it change with the clutch pulled in? I found the clutch quite noisy on mine.
    Jul 2017
    Sarasota
    Quote Originally Posted by Rockbyter View Post
    The sound is coming from the other side from what I can tell. It does not change with the clutch pulled in.
    Winind: My friend said that it must have a dry clutch.
    WV... Northern Panhandle
    You need a new friend.
    02 aprilia Futura
    15 aprilia Caponord 1200
    apriliaforum newb ANDREW MAC's Avatar
    Oct 2016
    england
    hi , I had this as well and I was told the same as normal it is how there are , THIS IS NOT TRUE , there is a problem and I can tell you it is the Timing gear bush and the special bolt . see photo attached , if you hold a screw diver to the c-head and hold in on to your ear you will hear the working sound of the inside working and then do the other c-head and you will hear the different sound . my got replaces just this week as it done 8000 and the nose got louder, see photo,
Size:  109.0 KBName:  IMG_2470.JPG
Size:  131.6 KBName:  IMG_2471.JPG
    Jul 2017
    Sarasota
    How long did they take to fix it after finally finding the problem? You mention c head. Is this the front or rear cylinder? I would think that if it happened to one it will probably affect both.
    Dec 2011
    Arizona
    When I bought my Rally 3 years ago I bitched at the dealer about the noise after only 400 miles. Got the same response 'that's a characteristic of the engine - nothing wrong here'. So after a few more miles, I forced the issue with the dealer, and he decided to investigate. Found the bushing in both cam gears to be totally worn out. Took a week and half to get the replacement parts in and couple of days to repair. All good now after 18500 miles.
    A quick check to see if the gears are out of spec is to observe the anti back lash teeth of the gear. If they are not aligned, it means that the clearance of the shaft an ID of the gear are excessive.
    Sent from my SM-G900P using Tapatalk
    Dec 2011
    Arizona
    Almost 1mm clearance of the shaft to the bushing ID. Makes a lot of noise!
    Jul 2017
    Sarasota
    It sounds like it may be a little difficult for the dealer to respond. I am supposed to go in this Saturday. Should I mention this being a possible solution or just complain about the noise?
    Dec 2011
    Arizona
    Quote Originally Posted by abnknows View Post
    This is a known problem at the distributor level, and your dealer should call it in to the area manager. More than likely they should OK labor time to look after the noise. Seems that Aprilia was supplied with some very soft out of spec bushings for the cam drive gear. These problem gears have shown up all over the place and I'm not sure Aprilia really knows if there is a series of VIN numbers that are affected. At any rate the proper gears work well.
    Dec 2011
    Arizona
    Quote Originally Posted by dograt View Post
    ps - My problem was detected early enough that the shafts were not destroyed.
    Jul 2017
    Sarasota
    Good news. They seen and heard the issue before. That is pretty disappointing that this would not be a tsb or warranty recall. I would think that this could be a catastrophic issue if not addressed quickly. Thanks again for chiming in. Hopefully they can get this fixed quickly. It will sound like a new bike...and with the lower gearing it will feel like it.
    Sent from my SM-J727P using Tapatalk
    Jul 2017
    Sarasota
    My dealer in Tampa let me take a demo 959 Ducati Panigale over the weekend since I live so far away. What a fun gorgeous motorcycle. I will never complain about the seat on the Capo after riding that for 800 miles. He offered me a GS1200 Adventure and said that he would not recommend it since I will want it after being on a Caponord (jokingly). I just can't get myself to like them. It is kind of like that Joke about Fat girls being fun, but not wanting to be caught on one.
    Jul 2008
    Mare Island, Ca. USA
    i'm at about 78k miles. i should probably have them look into this.
    Dadsafrantic
    2015 Red Caponord #64
  1. Engine Tick/Tap/Click noise when warm
    By ooter in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 03-24-2015, 02:21 PM
  2. clicking and ticking sounds
    By 7Brothers in forum 2010-2018 RSV4 - All Variants
    Last Post: 10-05-2013, 06:01 PM
  3. Click/Tick During Braking
    By SilverFoxUno in forum 2008-2014 Mana 850 and Mana 850 GT-ABS
    Last Post: 09-23-2008, 04:39 PM
  4. Bike Wont start or tick, Can be bumped. Pissed Off
    By therefused in forum RS125 Euro-archive
    Last Post: 10-19-2006, 11:05 AM
