Results 1 to 6 of 6
Thread: Sometimes you get lucky!
    Bloke whose 1200 Sport I rollerised 2000km ago calls me. Oil can warning is on on the dash.
    OK, don't ride it, I'll pick it up, (He's in Sydney, 550km round trip but better safe than sorry.
    Usually it's the sender switch so tank and airbox off, swap the switch but it looks very dry I. There..... Hmmm.
    Fire it up, still got the oil can. Bugger! OK, sometimes they blow the gasket out between the sump spacer and the block.
    Drop sump and spacer. Gasket intact. Double Bugger!
    Pull injector connectors and spin motor with finger over pick up orifice. No suckee!
    Roll shoulders in, pull tank and airbox again. Drop alternator, yank pulley, drop off oil cooler etc, pull Timing cover and
    That'll do it every time. It's the oil pump gear!
    Examining it in 'The Office' with my offsider we find the fucking gear is hollow!
    So who are the quality control assholes in Noale, (Can't pin this one on Mandello!)
    Pete
    Professional Goat Burster.
    Aug 2005
    Perth W/Australia
    But, we sava da munny !!
    Tuono Racing + KTM 990 Adventure =
    Dec 2015
    Sydney
    Didnt know that the "office" served frosty ones!?
    Anyhoo, you think that the molding bubble caused the teeth to shear?
    apriliaforum expert ScottG's Avatar
    Apr 2013
    wpbfl
    I've never seen anything that had a plastic gear that I thought it was a better idea than metal, just cheaper. Stripped teeth, broken in half, cracks around shaft or insert or just flat out slipping around shaft or insert, total junk idea in the first place. Anyone in your area make gears? I know it's expensive to have made but you won't have to do the same job again.
    Scottsdale, AZ
    Same shit happened with Harleys shortly after AMF aquired that company. Hopefully those hollow gear teeth were a one-off production defect, though they do look too consistent to be a defect.
    There are thousands of 8V's out there with the phenolic gear. If it was a terrible mistake they'd all be crashing and burning. They aren't.
    As it is the ex importer had one in stock still and I bought it. Turns out it is the earlier steel gear so problem solved.
    Pete
  1. play w/ the bulls, sometimes you'll get the horns
    By Racer X in forum General Motorcycle Talk
    Last Post: 07-16-2013, 09:10 PM
  2. Sometimes you're just lucky
    By zuman in forum 2008-2014 Mana 850 and Mana 850 GT-ABS
    Last Post: 10-27-2008, 05:09 AM
  3. SOmetimes, you can get a deal on eBay
    By Firebolter in forum SL1000 Falco Forum (all years)
    Last Post: 05-13-2005, 03:12 PM
  4. how do you get a good clutch start from 0mph at lights
    By memphisrs50 in forum RS50 Technical
    Last Post: 06-19-2003, 02:58 PM
  5. Did you get your new warranty?
    By ebetzs in forum Aprilia and Piaggio 500cc
    Last Post: 10-28-2002, 10:42 AM
