Results 1 to 3 of 3
Thread: Scarabeo 50 4t no spark, need debug procedure
    Jun 2017
    Atlanta
    I bought a 2006 4t and am trying to get it running. I've rebuilt the carb and cleaned the fuel tank, but now I find I have no spark. None. The battery is new and the bike is cranking over fairly fast, but no spark. I've tried to follow some debugging procedures on the internet like this one (http://www.pedparts.co.uk/blog/piagg...-fault-finding) but it does not quite match the bike and so I can't really trust the results. I will say that when I measure the resistance at the connector on the right front side of the case (stator/pickup ?) I get 178 ohms. The wire colors are yellow and brown.
    The plug wire and cap seem to be in excellent condition. No evidence of corrosion, insulation problems, etc. when I removed them.
    The ignition/coil module was made by Ducati. Resistance between the high tension lean and the closest 2 low voltage leads is around 2k ohms, and the farthest 2 leads is around 1 M ohm. Resistance between the first 2 pins is 348 ohms, and between pins 3-4 is infinite.
    Can anybody tell me how to tell why I'm getting no spark?
    Thanks.
    ontario
    the wires going to the cdi should be giving 14-70v of power from the stator. then if the cdi wont spark... better find a new cdi to test it with.
    you can try a new sparkplug and screw the sparkplug wire in all the way at both ends
    --- diploma for engine repair in 2012 ---
    derbi bullet 2006 - piaggio AC - malossi T.C. half - custom GPS dash - TPR 70CC - topperf crank - vl13 reed and spacer- yamaha rt180 kickstand - giannelli shotV4 - phbg 21mm - doppler mesh top venturi filter
    complete wtp volta bmx 2012 - sanko seamless japanese cromoly heat treated and blue printed frame - 21lbs
    1992 lt250r suzuki quadracer - maier plastics -chromed shearer pipe - chromed works suspension - ++++++++ - 220lbs
    apriliaforum Member KarimK's Avatar
    Apr 2017
    Calgary, AB
    Do a hz reading of the signal wire going to the ignition coil
    2005 Derbi GPR 50 Nude - SR 50 replacement
    80cc Malossi MHR Replica kit
    21mm Polini CP
  1. No spark on Scarabeo 50 4t 2006. Can you help?
    By BeOfService in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 07-25-2017, 07:01 PM
  2. Spark advance for Scarabeo 50 4T 2V
    By hunket in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 11-27-2014, 09:36 AM
  3. X reg Scarabeo 50 4t - Cut out - No spark
    By Mgriff1887 in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 08-29-2014, 11:30 AM
  4. Scarabeo 50 4T Tuning/Performance parts
    By Micah / AF1 Racing in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 06-09-2013, 10:06 AM
  5. Scarabeo 50 4T Need Help Scooter Stalls on Startup
    By robewilbur in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 08-16-2007, 03:33 PM
