Results 1 to 5 of 5
Thread: And now the transmission....
    apriliaforum prov-nov vermi's Avatar
    Jun 2014
    montreal
    Angry And now the transmission....
    After fixing my exhaust problem with backfire on my Typhoon, i was riding quietly and suddenly there was a metal friction noise coming from the rear wheel ... At home I removed the clutch and turned the rear wheel to hear a grunting of the rear gears! .
    So on Monday I brought the scooter to the dealer who installed the Malossi kit 80cc with the gears ratio.
    First question they said to me, "Is there any oil in the transmission box?"
    "I d'ont know you are the one who did the job last May ....."
    He lost his smile and now I await the verdict!
    Jenison, Michigan
    Oh no! I hope they make it right...
    2009 SR 50 Factory
    Malossi 70cc BBK
    Malossi HPC Crankshaft
    Stage6 Waterpump Impeller
    Arrow Extreme Pipe
    Malossi VL 13
    Ecu De-restricted 2.8.0
    7 Gram Dr. Pulley Sliders
    Stage6 Soft Contra Spring
    Water Trap
    RS 24/10
    Stage6 260mm Front Brake
    Stage6 R/T Clutch Bell 460g
    Malossi Special Belt
    Malossi E5 Air Filter
    Fuelab 535 FPR
    Glowshift Dual Needle Gauge
    Stock Gears Installed
    Jun 2014
    montreal
    I had my scooter today, it cost me $ 200!
    They changed 3 bearings in the transmission.
    The mechanic says at 10 000km (6200 Miles) it is normal that the original bearings burn with the new kit 80cc, turns faster and more torque. They installed SKF bearings sealed and should be more resistant.
    Back on the road!
    Jun 2013
    croatia
    no its not normal for the gearbox bearing to fail
    Jenison, Michigan
    Quote Originally Posted by jog View Post
    I've never seen gearbox bearings fail because of a BBK. It's always been from poor quality oil or lack of lubrication.
    2009 SR 50 Factory
    Malossi 70cc BBK
    Arrow Extreme Pipe
    Malossi VL 13
    Water Trap
    RS 24/10
    Fuelab 535 FPR
  1. Low sided my bike and now the dash has gone a bit crazy. (pics)
    By ianofbhills in forum 2010-2018 RSV4 - All Variants
    Last Post: 11-03-2012, 02:19 PM
  2. And now the LEO-free return trip...
    By DrDuc in forum SL1000 Falco Forum (all years)
    Last Post: 08-25-2010, 03:24 PM
  3. Just got the new Bike! and now the questions
    By crojack in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 02-07-2007, 10:25 PM
  4. The coolest Sprockets in the World...and now for Aprilia
    By micah apriliaforum com in forum SL1000 Falco Forum (all years)
    Last Post: 12-29-2002, 08:14 PM
