Results 1 to 10 of 10
Thread: V twin 'lazy' cylinder.
    Dec 2015
    Sydney
    Hi all,
    can anyone please explain how a 'lazy' cylinder comes about in a V twin and how to correct it?
    Thanks.
    Feb 2005
    MO, US
    Injected or carbs?
    What do you mean by a 'Lazy' cylinder Chris?
    Professional Goat Burster.
    37 miles E. of ATX, TX USA.
    Confusing terminology to me here. All odd fire motors do breathe slightly differently cylinder to cylinder due to acceleration and deceleration of the crankshaft but even in a v-twin it is not a crazy big difference in volumetric efficiency.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Dec 2015
    Sydney
    Well when researching this I came across the term in a post of yours years ago in the V11 forum.
    (You mentioned small blocks having to use smaller jets on the 'lazy' cylinder in order to pass pollution laws.)
    It refers to the following cylinder running rich due to the fact that the compression stroke is aided by the closely preceeding other cylinder - at least thats my guess, hence this posting.
    Just had a talk with a Ducati super bike mechanic and he said its not unknown for the rear cylinder to run 50% richer than the front!
    If it's running 50% richer there's something very wrong with it!
    Yup, I thought you might be referencing something like that.
    The firing intervals on a shared crankpin 90* twin are 270/450 degrees. The longer interval allows longer for the crank to slow due to frictional losses so even if the difference is miniscule at lower crank speeds especially it will result in differences in volumetric efficiency between the two cylinders and consequent fueling differences. It's why modern (ish.) twins all use a delta map to compensate for differences between the two cylinders. This is particularly true on a bike like the Griso with its odd, asymmetric exhaust system.
    Pete
    If you have a 50% fuel table Delta on any twin cylinder motor that motor or the base mapping is FUCKED. The only times I intentionally heavy bias fueling deltas in tuning is towards the rear cylinder on narrow angle v twins like HD motors, this is not a power strategy but rather a thermal control strategy. One HD motors the rear cylinder gets almost zero effective air cooling at low speeds typical of the breed while the front gets fantastic cooling. You can run the front cylinder at peak power mixture and the rear biased as much as 2 full afr points richer with say -2 to -4 degrees ignition lead biased rear to get a somewhat more thermally stable engine at street and highway cruise speeds. Water cooled motors are in no way biased for thermal control only to correct the very small VE difference between cylinders. When talking carburetor tuning yes sometimes you have a 4 main jet size or greater difference front to rear on a dual carb twin, carburetors are infinitely more fickle about small pressure and time differences of intake open event than EFI equipped machines.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Dec 2015
    Sydney
    Quote Originally Posted by sburns2421 View Post
    Injected or carbs?
    Sorry, missed this for a while but I suppose both systems are an issue.
    Dec 2015
    Sydney
    Thanks for the replies guys.
    The 50% richer on the rear seems hard to believe I must admit so I will chase it up to see if it was just bravado or not.
    That would mean on a superbike engine the front cylinder was making 125bhp or so and rear 75bhp or so...such a thing would shake itself to bits in little time.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
  1. Twin cylinder sports bikes. What's available?
    By Peter S in forum General Motorcycle Talk
    Last Post: 03-17-2014, 03:49 PM
  2. 1000cc V-Twin vs 1000cc 4 Cylinder
    By clarkie49 in forum Aprilia Privateer / Club Racing
    Last Post: 12-17-2005, 03:24 AM
