Results 1 to 4 of 4
Thread: 2013 Dorsoduro rev counter
    Jul 2017
    South Africa
    Hi guy's
    So i am a first time Dorsoduro owner and i love the bike it has a bunch of extras on it and a week back i had the arrow map done on it
    On my way to the dealer after some hard riding getting on the highway i notest that the rev counter now was no longer doing it job but sitting to the side
    The dealer just said it need a new speed cluster at a cost of 13500 Sa Rand just over 1000 us that is a hell of a lot
    well i did remove the speed went on some forums and some of the v4 guy'S have the same ting happen and the cluster looks the same but i could not get mine open
    It just looks like the needle has come of the shaft
    has any one had the same problem and has any one oped the cluster
    Jan 2016
    Vancouver, BC, Canada
    I have had this happen on other vehicles. An easy fix usually once you get to it. Normally just a very small splined shaft. Put a dab of locktite or glue on it and press back on in the proper spot and you should be good to go. T
    Jul 2017
    South Africa
    Hi thanks for the respond
    i think that would work if i could get too it I cant get the front cover of
    i took the 5 self tappers out and took plastic card and went around the edges and black sealer came loos but no luck opening the cluster
    I seem that it has more sealer wear i cant get to it i really dont know any more
    Jan 2016
    There should be a way for it to split but I have not had mine apart so I can't say for sure. Usually you would take the back cover off and then unscrew the gauge and take it out the back. Do what you have to. It went together so it has to come apart. Used ones can sometimes be sourced from ebay etc too if it is fubar or gets unrepairably damaged during disassembly. Good luck... Tom
  1. Another Rev counter problem
    By warmachine in forum RS125 Euro-archive
    Last Post: 03-25-2004, 04:23 AM
  2. rs250 Rev counter wanted
    By leighton in forum RS250
    Last Post: 03-15-2004, 08:31 AM
  3. Rev Counter
    By BLacKPooLLaD in forum RS125 Euro-archive
    Last Post: 03-11-2004, 08:09 AM
  4. rev counter broke , how do i fix it ?
    By BUTCHRS125 in forum RS125 Euro-archive
    Last Post: 11-30-2003, 03:36 PM
  5. How does rev counter work????
    By RSmokey in forum RS125 Euro-archive
    Last Post: 09-07-2003, 06:39 PM
