Results 1 to 8 of 8
Thread: Scotch Chalkboard tape - for mirrors
    apriliaforum Member VicVen's Avatar
    May 2016
    Oregon
    Hi.. just passing along a tip of something I found today.
    The mirror stems on my 2016 RSV4 seem prone to nicks more than anything else.
    Today I came across this "chalkboard" (removable ) tape made by Scotch that is almost the same identical color as the mirror posts on the bike.
    I cut to shape four pieces and placed them along the leading edge of the stems, where the nicks appeared most often.
    It matches so well that I was having a hard time taking a photo where you could see the tape. I had to put a light on it so you could see it.
    It was about $7 at a local closet organizing store.
    No more nicks !!
    apriliaforum Junkie CrankyGypsy's Avatar
    Oct 2005
    Tampa
    great find. thanks for sharing.
    how well does that tape pull up?
    my mirrors are taking shots, but it's my matte fairings that are looking awful and bumming me out. i did a quick experiment with Plasti Dip since it's too late for the fairing film. the Black is monochromatic, so doesn't match the subtle metallic of the Aprilia color. but i found that Plasti Dip Clear Matte blends very well and even helps hide the chips that are already there!
    my only issue with it is the spray can version: though it worked great in the small test patches, it did not lay down smooth over the entire panel for me. since i had the panel laying horizontal rather than hung vertical, i think it was drying too fast and caused the overspray to build up across the middle of the fairing. though i got great results on the leading edge of the panel, this gave some of it a texture along with a slightly opaque appearance. so, i need to experiment a little more with my method/technique (i.e. vertical). taping-off and spraying smaller sections helps to get an almost invisible finish. however, i found pulling the tape up can slightly lift the Plasti Dip, making the edge noticeable with the Clear Matte only. i also have some paint guns i used for boat gelcoat that should lay it down wetter if i buy it by the can.
    2000 SR50 LC (Minarelli; Arrow pipe). 2002 SR50 DiTech LC (Morini; water trap; CPR8E).
    sold: 2014 RSV4 R APRC ABS (EVAP & SAS delete; AF1 coolant clamps; FP Racing Levers)
    sold: 2004 RSV1000R Factory (VIN#00001; Akro System; Sato rearsets; retrofitted 2003 stator)
    apriliaforum expert MamboItaliono's Avatar
    Jan 2015
    Oahu, Hawaii
    Very cool tip!
    apriliaforum Member Juggy82's Avatar
    Oct 2015
    Townsville, Australia
    Awesome idea. I got sprayed by stones coming out of a roadworks area and it kills me seeing the chips on my mirror arms. Will head out this weekend to get the tape lol
    Thanks mate.
    2015 Ascari Black RSV4 RR
    SC Project GP70R exhaust and race ECU
    May 2016
    Oregon
    The tape peals off easily. It is "removable" tape, as it says on the box. No residue or paint damage.
    apriliaforum expert Didka's Avatar
    Jun 2013
    Belgium
    Thx man..
    apriliaforum prov-nov KnoxRider's Avatar
    Dec 2015
    Knoxville, TN
    Okay, how did you get the tape to stick?
    I bought a roll, cut some pieces......didn't prep the surface.....and naturally they peeled off by the next morning
    apriliaforum Member ZX6Rocket's Avatar
    Aug 2015
    Orange, Ca
    prep surface with rubbing alcohol....
  1. Looking for Mirrors, tag bracket, & turn signals
    By MRichardson in forum 2009 RS125-USA
    Last Post: 08-19-2010, 12:36 PM
  2. fabricated brackets for mirrors
    By toold2rocknroll in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 06-11-2008, 07:58 PM
  3. Suggestions for Mirrors?
    By spectda in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 01-11-2007, 12:51 PM
  4. Heat tape for heat shield
    By mossback in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 03-12-2006, 09:02 PM
