Results 1 to 2 of 2
Thread: Help removing water pump belt
    Feb 2015
    salem, ma
    Does anyone know a good way to remove the water pump belt. It seems very tight and I can't see any tension adjustment. I need to remove the pump shaft so the belt has to come off
    Jenison, Michigan
    Welcome to the forum! What bike do you have? I'm guessing a Piaggio engine. If that's the case, you have to take the variator off and then it's pretty self explanatory.
    2009 SR 50 Factory
    Malossi 70cc BBK
    Malossi HPC Crankshaft
    Stage6 Waterpump Impeller
    Arrow Extreme Pipe
    Malossi VL 13
    Ecu De-restricted 2.8.0
    7 Gram Dr. Pulley Sliders
    Stage6 Soft Contra Spring
    Water Trap
    RS 24/10
    Stage6 260mm Front Brake
    Stage6 R/T Clutch Bell 460g
    Malossi Special Belt
    Malossi E5 Air Filter
    Fuelab 535 FPR
    Glowshift Dual Needle Gauge
    Stock Gears Installed
  1. Removing water pump impeller
    By BarryG in forum RS250
    Last Post: 02-27-2015, 08:03 AM
  2. HELP! Removing Fuel pump assembly?
    By gnonne in forum Aprilia and Piaggio 500cc
    Last Post: 08-14-2012, 09:12 PM
  3. How to remove Water Pump Impeller to change seal?
    By Forza Rapallini in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 10-20-2011, 09:23 AM
  4. removing water pump impeller
    By coolkev in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 09-01-2009, 11:01 AM
  5. Help! water pump seal removal
    By meekerdb in forum RS250
    Last Post: 12-10-2006, 12:21 AM
