Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
Thread: DD 1200 Engine Rebuild, New undercut gearbox. Need any pointers on what you would do.
    Nov 2016
    Australia
    thats a fair bit of engine mods going on there! does undercutting improve performance?
    apriliaforum prov-nov Mattix415's Avatar
    Mar 2015
    Cape Town, South Africa
    Quote Originally Posted by truck View Post
    Hey man,
    Well new rings and seals should give me a little boost and also the exhaust being ceramic coated and heat wrapped will give a few HP. Also i did chop out the cats so the bike is going to be stupid load with the Arrow cans but hey load pipes save lives!
    The under cutting will just make the gearbox take more load and have less chance of stripping the dogs on the gears. basically the more power the tighter the gear sits in the dogs.
    Mar 2015
    Mar 2015
    Head was removed off one cylinder and it looks like the stock pistons are actually billet pistons and not cast iron. Which is very interesting as they are 106mm which is massive! Looking forward to getting down to the crack to see what the conrods are and if they are any decent on these engines.
    Going to get the walls deglazed, after 40 000km they are not in bad shape but will need a deglaze in order to seat the new rings nicely.
    37 miles E. of ATX, TX USA.
    Stock pistons are forged aluminum, the final machining is done with CNC though which gives that billet looks. You would probably not want billet pistons as they would contain a metal grain structure very undesirable for uniform expansion as the piston heats and cools. The cylinder walls are Nikasil plated (nickel, silicone, carbon) plated aluminum alloy, piston rings are steel. At 40k miles there really should be no more wear than perhaps a slight polishing of the thrust surfaces of the nicasil bores, cross hatching should be visible still though they may "Feel" smooth to the touch.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Mar 2015
    Hi Micah,
    Thanks for the comment!
    So then would you suggest i go ahead with the deglazing to get the new rings to sit nice? The cylinder walls are like a satin texture smooth to the touch but there are visible.
    I would just do a VERY LGHT HONE on a sunnen type cylinder honing machine, attempt to hit 30/60 degree crosshatch angles.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
  1. Went down today, need some help on what to expect.
    By SnyderJ21 in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 05-22-2013, 12:36 PM
  2. Photo, need peoples opinion on what screen this is
    By Wayno in forum SL1000 Falco Forum (all years)
    Last Post: 06-05-2010, 06:59 PM
  3. new pads, now front tire barely spins...what did I do wrong..
    By steveT in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 04-11-2009, 03:49 PM
  4. RS250 Engine Rebuild (New Zealand)
    By Timati in forum RS250
    Last Post: 04-23-2008, 02:31 PM
  5. New to site - Need help deciding on '03 Aprilia?
    By KindredSpirit in forum General Motorcycle Talk
    Last Post: 06-15-2005, 04:56 PM
