Results 1 to 12 of 12
Thread: Can someone offer advice on up-jetting please?
    Mar 2017
    USA
    2001 Aprilia Scarabeo 50 / Minerelli Eng. / Dellorto Carb.
    Installed:
    Tecnigas Trek pipe
    Airsal 046 / 65cc bore kit
    The Dellorto carb has a "7.0" main jet and i understand that you typically go up 10% when adding a sport pipe. But since i have added a sport pipe and 65cc bore kit, I'm wondering if i need to go larger on the jet. Also, my jet kit jets are in increments of 5, so 7.5,8.0,8.5... etc...
    Any insight on this would be greatly appreciated.
    TIA
    Ken
    ontario
    what diameter is the carb? is it the phva 17.5?
    is it a stock carb with a stock airbox. stock rollers and contra spring. stock clutch and springs?
    Mar 2017
    USA
    Phbn 12
    Mar 2017
    USA
    sorry... missed the other questions.
    phbn 12
    stock airbox
    will change out rollers to compensate for the 1500 contra and clutch springs.
    ontario
    thats the problem then. its too small. correct sise is 15mm and up.
    we have a guy here working on tuning a sub-100 dollar FULL setup. join him if you want or get the big bucks malossi carb and filter and intake. not fun at all.
    what do you want to do? your carb is half the cfm it needs to be. it will not run long before your on the side of the road with the 12mm
    Mar 2017
    USA
    Ok... thanks.... BTW... what are the torque specs for the exhaust? Do you happen to know?
    Also, do you recommend a carb upgrade for this setup?
    ontario
    12ft/lbs for m6 bolts i think but you can double check.
    our member JIXAW is working on a dellorto/dakar sha 15mm. he paid like 80usd for the carb/adapter and tunR airfilter. its a simple carb for a reasonable price. it fits great but he could use a partner to help dial it in twice as fast.
    otherwise the phva or phbg could work. thats like a 200 dollar setup. and its custom. not really a bolt on thing. more like a major project.....
    i like jixaws setup.
    Mar 2017
    USA
    BTW... this Airsal Kit instructions say that this cylinder runs perfectly with original carburetor....
    ontario
    so you want to put the stock pipe on? does sound like a really easy way to fix it. that manual is handy lol
    Dec 2015
    Cambridge, MA
    i grabbed a Dakar SHA 15.15 like sublunacy recommended.....its so easy to tune and my mojito is really fast now....i'm mostly dialed in but am still fine tuning......if you need any advice, let me know.....
    2003 Vespa ET2 50cc
    2001 Triumph TT600
    1993 Yamaha Razz 50cc
    ontario
    yeah theres jixaw now. i hope he gets it perfect because with that new filter the setup is tremendous!
    Sep 2015
    us
    Like everyone says you need to upgrade the carb. If this helps, I have a 2001 Scarabeo with a 70cc sport kit but with an aftermarket non expansion SP3 pipe.
    I put on the 17.5 Dellorto PHBN and Malossi Multivar variator . I use a 78 main jet (stock 50cc is 70) and the pilot that came in the carb (can't remember the size). I also use the white torque spring that came with the variator and stiffer clutch springs (blue I believe)
    I get 53 on flat with great pickup.
  1. Replies: 26
    Last Post: 10-04-2016, 02:23 AM
  2. Advice on gearbox issue please chaps
    By wiper in forum 2012-2017 Tuono V4 - All Variants
    Last Post: 09-23-2015, 11:48 AM
  3. Need advice on re-jetting a 2014 Piaggio Typhoon 50 ( 4v - 4t )
    By Dave Bo in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 07-15-2014, 03:08 PM
  4. Racers advice on running-in please..
    By FlyingScot in forum RS250
    Last Post: 04-24-2005, 04:16 AM
  5. Need Advice on pipe, jets and sprocket mods for my Peg
    By Flying Mythos in forum Pegaso 650 Cube and IE
    Last Post: 02-25-2003, 07:02 AM
