Results 1 to 7 of 7
Thread: 2004 Aprilia Rally 50
    Jun 2017
    North Aurora
    I have a 2004 Rally 50 that runs but with limited power. Mechanic feels the exhaust is clogged and should be replaced. We have new fuel, plugs, carb is cleaned. Has anybody had this problem. Also, the exhaust is not available. Any help would be appreciated.
    ontario
    sounds fishy but it could happen.
    quite simply a better touring exhaust should do the trick then.
    2004 ? is that a piaggio branded engine or pre-piaggio? i need to know so i can recommend the carb tuning if needed.
    i like the leovince touring pipe alot. i think narraku cloned it.
    ~ does that help?
    --- diploma for engine repair in 2012 ---
    derbi bullet 2006 - piaggio AC - malossi T.C. half - custom GPS dash - TPR 70CC - topperf crank - vl13 reed and spacer- yamaha rt180 kickstand - giannelli shotV4 - phbg 21mm - doppler mesh top venturi filter
    complete wtp volta bmx 2012 - sanko seamless japanese cromoly heat treated and blue printed frame - 21lbs
    1992 lt250r suzuki quadracer - maier plastics -chromed shearer pipe - chromed works suspension - ++++++++ - 220lbs
    Jun 2017
    North Aurora
    Thank you for your help. How would I know if it is piaggio or pre-piaggio? I know nothing about these bikes. It was bought in the US. They did not make very many of these models for sale in the US. I bought it off a guy for my daughter to use at college. Has run great up until recently. I have been trying to buy the exhaust with not luck. Aprilia does not make it anymore. If I can find the proper after market I will purchase it. I am having trouble finding the correct set up.
    ontario
    mechanics are poorly suited to fix scooters. can you do a twostroke tune-up with some help?
    »try racingplanetusa.com it says you have a horizontal minarelli with a tiny carb. the polini exhaust looks perfect for 50cc. free shipping too.
    Jun 2017
    North Aurora
    Yes.
    Thank you I will take a look
    ontario
    Quote Originally Posted by spags View Post
    Yes.
    you might need a couple mainjets slightly larger than stock. should be the 5mm jets but i do not know what the stock size is.
    ttyl
    Jun 2013
    croatia
    check the wear of the belt and the transmission main spring and weights
  1. 2004 Aprilia Rally 50 Help?
    By BreathinFire in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 01-31-2013, 12:55 AM
  2. 2004 Aprilia rally 50 in Louisiana
    By don63 in forum Aprilia Motorcycles and Scooters for Sale / Wanted
    Last Post: 06-09-2012, 07:52 PM
  3. Aprilia Rally 50
    By -JiMmY- in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 06-21-2008, 04:20 PM
  4. 2004 Aprilia Rally 50 scooter
    By hlleonard in forum Other Aprilia Models
    Last Post: 03-19-2006, 02:21 PM
  5. My Aprilia Rally 50
    By Dutch Royal T in forum Aprilia Owner's Pictures, Videos, and Sounds
    Last Post: 09-25-2001, 04:01 PM
