Results 1 to 12 of 12
Thread: 2006 Scarabeo 50 4t slow acceleration
    Jun 2017
    Minneapolis, MN
    Just picked up a friend of a friend's 2006 Scarabeo 50 4t with only 880 miles that hasn't been started in 5 years. The scooter is in mint condition. I took the time to dump the fuel, break down and clean the carb, replaced the jets, replaced the spark plug and give it a good overall look. Now the scooter starts up with no problems.
    I haven't ridden a scooter since 2003 and that was a Zuma, so I am not sure if this is normal. When I open up the accelerator to full, it takes a good time for it to get up to 25 mph, say 1/2 mile. Is this normal? Also, what would be the top speed? I have only ridden it in my neighborhood, so after 1/2 the most I could get was 30 mph.
    If this is not normal, I would love some ideas as what to look at.
    ontario
    can you be more specific please. or perhaps post up a running video
    Jun 2017
    Minneapolis, MN
    Here is a short video I made. I can only get this up to 20mph. Hard to tell from the video but it bogs down when I open up the accelerator to full. I removed the air filter to see if that helped, but it doesn't. Thanks for any help you can give.
    https://youtu.be/2TcJZqxuPMs
    ontario
    it seems like it is starving for fuel. if you have a perfect idle then maybe clean the needle and mainjet.
    i would double check for mice nests in the intake/head or exhaust pipe.
    hope that helps.
    i think im confused about the air blasting around but the cvt/trans has some fanning action. it does not look aircooled so that is not it.
    Jenison, Michigan
    The air flow is normal, it's an air cooled 4 stroke. There's a fan that blows air throughout the housing. Definitely a carb problem. If it's completely stock, make sure the jets used are the same as stock also. Put the clip for the needle in it's stock position. Put the air filter back on. Removing it is gonna make it run lean. Make sure the float is properly set and the fuel inlet isn't plugged up. Check your fuel filter and recheck to see what the plug looks like. Sounds like it idles great though.
    2009 SR 50 Factory
    Malossi 70cc BBK
    Malossi HPC Crankshaft
    Stage6 Waterpump Impeller
    Arrow Extreme Pipe
    Malossi VL 13
    Ecu De-restricted 2.8.0
    7 Gram Dr. Pulley Sliders
    Stage6 Soft Contra Spring
    Water Trap
    RS 24/10
    Stage6 260mm Front Brake
    Stage6 R/T Clutch Bell 460g
    Malossi Special Belt
    Malossi E5 Air Filter
    Fuelab 535 FPR
    Glowshift Dual Needle Gauge
    Stock Gears Installed
    Jun 2017
    Minneapolis, MN
    Ok thanks, I will have to do some more work on the carb and check the exhaust. The idle jet and main jet are brand new. I did not change the needle, it looked fine and I cleaned the entire carb. The only jet I did not change is the accelerator jet that is in the corner of the carb. Very tiny hole and I blew carb cleaner thru it, or at least I think it was going thru it.
    Jun 2017
    Minneapolis, MN
    Have two more questions. First is the order of the jet pin. The diagram looks to be incorrect or I placed it incorrectly. After I install the diagram I put the pin in, then the clip, then finally the spring on top of the clip. The diagram seems to show it differently. Here is the diagram and a pic of how I installed it. Which is correct?
Size:  62.4 KB Name:  20170612_215134.jpg
    Second question is what is this and where does it go? It looks to be a drain hose, but I have been unable to locate where it goes.
    Dec 2015
    Cambridge, MA
    can you see what the main jet looks like?...can you confirm that its clean? do you know what size main jet?
    2003 Vespa ET2 50cc
    2001 Triumph TT600
    Jun 2017
    Minneapolis, MN
    Found a better diagram and it looks like I did it the correct way. This is from the service manual.
    ontario
    so you got new jets? it sounds like a clogged mainjet.
    is there an emulsion tube on that carb? they get clogged up also because of the possible small holes in it.
    Jun 2017
    Atlanta
    +1 The emulsion tube under the main jet has tiny holes that need to be clean. Even with a new jet the air/fuel will not mix right unless that tube is clean in and out. I used a thin guitar string to clean mine out.
    Good luck!
    Jun 2017
    Atlanta
    The drain on the bottom of the carb has a short cast aluminum tube that that hose slips over.
  1. 2006 Aprilia Scarabeo 50 4T - electrical problems. Help wanted/welcome/neeed.
    By swherbig in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 08-26-2013, 12:22 PM
  2. Scarabeo 50 4T Tuning/Performance parts
    By Micah / AF1 Racing in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 06-09-2013, 10:06 AM
  3. Help with pricing a used 2006 scarabeo 50 4t Scooter
    By WChap in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 08-20-2012, 07:44 PM
  4. 2006 Scarabeo 50 4t Front Wheel Washer
    By manhattanite in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 08-31-2009, 10:13 PM
  5. How can I speed up my 2006 Scarabeo 50?
    By cdmcsulb in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 05-21-2006, 02:30 AM
