Results 1 to 7 of 7
Thread: Ok, I need new tires for my SR50. help!
    Sep 2016
    FL
    I'm probably going to hire someone to change out my tires (busted the rear, front is shot too), but I want to buy them.
    What size and type am I looking for?
    I have a Sr50 carb 2001 model.
    Thanks,
    Jenison, Michigan
    130/60 13, Michelin Power Pure, Amazon
    2009 SR 50 Factory
    Malossi 70cc BBK
    Malossi HPC Crankshaft
    Stage6 Waterpump Impeller
    Arrow Extreme Pipe
    Malossi VL 13
    Ecu De-restricted 2.8.0
    7 Gram Dr. Pulley Sliders
    Stage6 Soft Contra Spring
    Water Trap
    RS 24/10
    Stage6 260mm Front Brake
    Stage6 R/T Clutch Bell 460g
    Malossi Special Belt
    Malossi E5 Air Filter
    Stock Gears Installed
    Sep 2016
    FL
    I can only find those in rear.
    Michelin - Pilot Power Pure SC Rear Tire 130/60-13 - Blackwall
    1x $61.19
    Can I get that for the rear and this for the front?
    Kenda - K413 Front/Rear Scooter Tire
    Color - Blackwall
    Size - 130/60-13
    Sku #49526
    Jenison, Michigan
    Stay away from the Kenda, it'll deform and can't handle the speed it's rated for. I just threw the one on my rear in the trash. Get 2 Michelins. They have arrows on them for front and rear. The front mounts opposite (flipped/backwards) from the rear.
    2009 SR 50 Factory
    Malossi 70cc BBK
    Arrow Extreme Pipe
    Malossi VL 13
    Water Trap
    RS 24/10
    ontario
    yes the kenda and continentals will be good also
    --- diploma for engine repair in 2012 ---
    derbi bullet 2006 - piaggio AC - malossi T.C. half - custom GPS dash - TPR 70CC - topperf crank - vl13 reed and spacer- yamaha rt180 kickstand - giannelli shotV4 - phbg 21mm - doppler mesh top venturi filter
    complete wtp volta bmx 2012 - sanko seamless japanese cromoly heat treated and blue printed frame - 21lbs
    1992 lt250r suzuki quadracer - maier plastics -chromed shearer pipe - chromed works suspension - ++++++++ - 220lbs
    apriliaforum newb westcoast1101's Avatar
    Sep 2017
    Vancouver Canada
    Hi biggestnewb what kind the tire u choose to you'r sr50 I have the same problem I have to choose tire I was looking for the kenda
    ontario
    kenda and irc and continentals are perhaps at scootertuning.ca
    the irc snow tires look awesome i think from the pictures.
  1. Need new stickers for the MANA. Help?
    By aristosv in forum 2008-2014 Mana 850 and Mana 850 GT-ABS
    Last Post: 12-12-2013, 08:53 PM
  2. Need to get a new back tire for my Vespa
    By jrflanne in forum General Motorcycle Talk
    Last Post: 08-14-2012, 08:45 AM
  3. I need new Tires!!! For My Mille
    By SirMille in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 10-11-2006, 01:33 AM
  4. i need tires for my 150 moj.
    By ffkevinking in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 09-23-2006, 02:10 PM
  5. Got a new part for my SL1000 *FIXED*
    By Klajorne79 in forum SL1000 Falco Forum (all years)
    Last Post: 03-01-2003, 03:05 PM
