Results 1 to 2 of 2
Thread: Sprag Clutch preload spring replacement
    Roma, Caput Mundi
    First part of sprag clutch assembly to fail is usually the preload spring... once that spring lose it's tension the bearing starts to permanently slide on the outer cage and thing starts going bad.
    BUT if cured in time, you can save the whole assembly just replacing that little spring. Same kind of springs are used in oil seal, the correct one is pictured below size 56x72x7 mm, you can buy it cheap: http://www.ebay.it/itm/56X72X7-AS-NB...0AAOSww9VXhCdI
Name:	corteco molla ruota libera.jpeg
    www.gabroracingteam.it
    Visit my FB page and like it!
    apriliaforum expert rocketnz's Avatar
    Jun 2011
    Bondi Beach
    Great find.
    0̶̶̶6̶̶̶ ̶̶̶A̶̶̶p̶̶̶r̶̶̶i̶̶̶l̶̶̶i̶̶̶a̶̶̶ ̶̶̶S̶̶̶X̶̶̶V̶̶̶ ̶4̶5̶0̶
    99 Aprilia RSV 1000 Mille
  1. How to replace your sprag clutch.
    By odie_trackie in forum 1000cc f.a.q
    Last Post: 05-01-2017, 02:39 PM
  2. Sprag Clutch Replacement Spring
    By Aus Rider in forum RST1000 Futura (all years)
    Last Post: 06-19-2010, 07:45 AM
  3. Clutch Shoe Spring Replacement
    By floydy15 in forum Aprilia and Piaggio 500cc
    Last Post: 05-22-2008, 08:44 AM
  4. Tools needed for Sprag Clutch replacement
    By Brian*E30 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 11-07-2006, 01:40 PM
  5. Sprag Clutch Replacement
    By Stephen1971 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-29-2005, 10:33 AM
