Results 1 to 9 of 9
Thread: Please explain clutch lever electrical connection
    Feb 2012
    Portland OR
    My RSV is plagued with random stalling when decelerating to a stop, and I've tried various "fixes" but it still continues. I noticed the electrical connection on the clutch lever, and see there's a small spring loaded diod type thing that gets depressed by a pin on the lever, once the clutch is fully engaged (see pic). So I'm wondering what exactly this connection does, and if it could be the cause of the stalling if its not operating properly. The bike starts/runs fine, idles smoothly at @1200, never dies while running, but randomly dies (once or twice during a ride) ONLY when decelerating to a stop w/ the clutch engaged. It doesn't shudder or stumble and just cuts out immediately.
    Thanks for any insight/advice
    apriliaforum expert locknload's Avatar
    Jan 2004
    Christchurch New Zealand
    If the bike is in gear it will not start but by pulling the clutch lever in it will operate this switch allowing the bike to be started in gear with the clutch in
    apriliaforum expert theknurl's Avatar
    Mar 2007
    Palos Verdes Est. SoCal
    Thumbs up ?
    TeddyG;
    The clutch switch is part of the safety start interlock system along with the neutral switch and side stand switch
    do a search or look in FAQ
    they all must be working..... they're slight differences​ between brands....
    Noel-theknurl
    The Forum Curmudgeon
    I'm not PC either
    email/PayPal theknurl@yahoo.com
    Skype theknurl
    ph. 310-414-7247 PST, GMT -8
    apriliaforum prov-nov peace maker's Avatar
    Queensland, Australia
    I don't know if this related but I had the exact same problem when I first bought mine. I started using 98 octane fuel and haven't had a stall since. May not be the same issue but worth considering. I don't know of a logical reason behind it, just sharing my experience. Good luck.
    2004 Aprilia RSV1000R Factory - Map 2, updated ECU map, PC3, Akrapovics, K&N air filter, Ricks's heavy duty stator, sh755 rectifier, T12 stator oil cooling kit, updated temp sensor, CBR1000 side stand, Ducati 1098 rear master cylinder.
    2012 Kawasaki Z1000 - GP series titanium Akrapovic slip ons
    apriliaforum prov-nov terrynewleaf's Avatar
    Dec 2016
    Australia
    pm sent..........I have the exact same issue! Did you find the fault?
    Thanks,
    T
    apriliaforum Junkie dfoustou's Avatar
    Aug 2014
    silver spring
    check the vacuum lines on airbox.
    Dionysis
    79 CX500C
    07 RSV1000R
    08 WR250R
    IBA#58777
    Nov 2017
    Brocks UK
    Take the clutch switch apart and spray it up with WD40 or contact cleaner, the same thing happens on my zx9r occasionally, it just gets grubby as does the sidestand switch, if mine were playing up too much they'd be bypassed, the tiny trigger on them gets gunged up too and tends to stick which is what I suspect is happening in your case.
    Feb 2012
    Portland OR
    Thanks for all the replies guys- my stalling problem turned out to be a bad stator
    Nov 2017
    Brocks UK
    I suppose it pays to check the little stuff first but it appears with these to be the case of anything electrical and the bikes fked, has anybody tried suing because this shit just shouldn't happen these days, whether these days is 2005 or not.
    I understand the bike to be great when its all going good but cmon, ten grands worth of bike let down by forty quid electrics, people seem to sue each other over any bloody thing today but try getting your moneys worth from a corporate and everybody and their aunty is against you.
  1. can anyone please identify this electrical connection?
    By asb2106 in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 05-18-2012, 10:50 AM
  2. Clutch lever part wanted please
    By random0082 in forum RS125 Euro-archive
    Last Post: 03-25-2007, 04:24 AM
  3. clutch lever part needed please!
    Last Post: 07-17-2006, 10:02 AM
  4. Replacing clutch lever.....???
    By AV8OR in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-21-2003, 02:26 PM
  5. Clutch Lever Switch
    By gi02sl in forum SL1000 Falco Forum (all years)
    Last Post: 06-05-2003, 08:19 PM
