Page 1 of 9 123 ... LastLast
Results 1 to 15 of 129
Thread: 2017 RF shock linkage
    apriliaforum Junkie aftriathlete's Avatar
    May 2016
    The Great American Southwest
    Motorcyclistonline.com says "revised leverage ratios," Sportrider.com says "new progressive linkage," and apriliausa.com says "it increases the reaction time of the shock." Anyone know what that all that means in rider terms? More progressive? Flatter? I heard someone mention on the UK RSV4/Tuono owners page that it makes a 10.5 spring in the back more like a 15.0, so it will require dramatically softer rear spring rates. I'm not a geometry wiz, so hopefully someone can translate what all that means to a club racer.
    2016 RSV4 RR Race Bike
    Dec 2016
    Phoenix AZ
    My assumption here. If "it increases the reaction time of the shock" then it would mean to me that you need more swingarm arc to get the same shock motion as previous models.
    BTW -- I am also in The Great American Southwest, Phoenix AZ to be more specific.
    Are you afraid to die or just afraid to LIVE -- No Fear
    apriliaforum expert Prospected's Avatar
    Apr 2013
    Annapolis, MD
    Quote Originally Posted by aftriathlete View Post
    The only bike I know of that requires a significant linkage change to improve its 'leverage ratio' is the zx10r due to its horizontally mounted shock. Several companies offer the kits. Go look at a pic of the Kawi WSBK rear end and see how they've completely re engineered the shock linkage, geometry angles, and switched to the conventional vertical design. I have a hard time believing Ape changed the bike to such a dramatic spring ratio.
    Jan 2016
    San Diego
    Piaggio has not yet listed up the 2017 parts availability for dealer access. (I already asked about 2B003744 Double Conrod) <--- The revised linkage part number.
    AF1 Ed is guessing the ratio has changed slightly due to the Ohlins TTX addition to the RF. And this makes sense because the 2017 RR has a different linkage part number (2B003070) than the 2017 RF. It seems overall they found better ratios, as the RR linkage changes from 2016 to 2017 as well.
    So there a few more guesses to make regarding using a 2017 RF linkage on another model....
    May 2016
    I'm particularly interested because I have a 2016 RR with off-the-shelf TTX GP shock, but obviously still running the 2016 RR linkage. So if this is going to improve drive/traction I'd be interested. But considering the bike is still "designed" for two-up riding, it still has to remain progressive for that reason right? So not likely they went to a more flat, race-type linkage? I don't know, I'm just talking through the questions.
    Jan 2016
    San Diego
    then please try the Forsaken link and let us know the before/after details.
    http://forsakenmotorsports.com/produ...spension-link/
    May 2016
    The thrill of the search and the research is half the fun to me when it comes to buying go-fast parts. Plus, if it's an improvement and all I need are new side linkage plates, then there's a chance it won't be incredibly expensive. So club racer double win!
    Apr 2016
    socal
ID:	331746Click image for larger version.
    I ordered this part (2B003744 Double Conrod) few weeks ago, i received today. I will be comparing to stock 2013 Tuono, with a 2016.5 RF OEM ohlins shock. I'll you guys know, after i test, next weekend.
    Aug 2011
    Italia
    With the new linkage spring has gone down to a 85 vs 105 of previous one , so it's quite obvious that progression is totally different
    Aug 2007
    San Antonio
    Quote Originally Posted by Hyper View Post
    what? I think you have that backwards.
    Everything ive read says the 17 RF now has a 105 spring, up from 95.
    Aug 2011
    Italia
    2015= 95 , 2016=105 . 2017= 85
    Aug 2011
    Italia
    2017 i mean last model with tft dash etc
    apriliaforum Junkie manjunathbs's Avatar
    Sep 2014
    Bangalore, INDIA
    Quote Originally Posted by 99cobra View Post
    Didn't see this in AF1 yet? Where did you order from?
    Are you trying this with TTX or RF Ohlins shock?
    No fear, no guilt, no shame, this is all that takes to be a man!!
    - Rudra Tandava
    Currently owned bike:
    2013 Aprilia RSV4 R APRC ABS
    Previously owned bikes:
    2012 Suzuki GSXR1000
    2012 Yamaha FZ1-N
    2012 KTM Duke 200
    Royal Enfield Bullet Electra (350)
    Apr 2016
    socal
    I ordered linkage from www.aprilianewportbeach.com, ask for Daniel. I will install using a 2016.5 rf oem ohlins with the stock 105 N/mm spring. I weigh 280lbs with gear, so we will see if it works.
    apriliaforum expert tomik's Avatar
    Oct 2005
    Finland
    Could you take measurements of the linkage before installing? I mean distance between mounting holes.
  1. Shock linkage service interval
    By Smoke Eater in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 11-09-2004, 11:11 PM
  2. Free Mille shock linkage
    By Katch in forum SL1000 Falco Forum (all years)
    Last Post: 03-04-2004, 08:44 PM
  3. won shock linkage, but...
    Last Post: 03-03-2004, 08:26 PM
  4. Mille swing/shock/linkage. Whats it worth?
    By tomas316 in forum SL1000 Falco Forum (all years)
    Last Post: 05-01-2003, 01:52 PM
  5. Mille rear shock linkage on a Falco
    By Silverfalco in forum SL1000 Falco Forum (all years)
    Last Post: 02-15-2003, 11:58 PM
