Page 7 of 7 FirstFirst ... 567
Results 91 to 101 of 101
Thread: 2017 Exhaust and Bike Notes
  1. #91
    Jun 2017
    Guelph, Ontario Canada
    was wondering this too. want to get one to play with to try and quiet it down a bit
    ordered one a while ago, I guess Akropovic takes quite a while to get stuff out.
  2. #92
    May 2016
    Liverpool
    I was speaking to pipewerx exhausts about this issue as my local track noise limit is 102dB with a flyby of 89dB. They recommended getting one of their race cans in a longer length of 450mm and using a baffle. For 300 all in you will recoup half that by not getting kicked off the track day http://www.pipewerx.com/race-exhaust...e-exhaust.html
  3. #93
    apriliaforum newb RSV417's Avatar
    Jul 2017
    santa clara
    has anyone weighed the complete stock system of the 17's? (can and headers)
    AF1 has the full akra system listed as weighing 10.4 lbs but strangely doesnt list the stock setup to show weight savings...
    Graves claims the stock exhaust is 13.5 lbs but compares that to their slip on (2.6 lbs).... im assuming the stock can alone isnt 13.5 lbs... but thats the only figure my initial googling turned up...
    AF1s listing for just the akra can says it about a 3lb reduction from stock (doesnt list the actual weight)...
    just curious more than anything.
  4. #94
    Oct 2013
    San Diego, CA
    Quote Originally Posted by RSV417 View Post
    Not the full system, but I today I weighed the stock can (with servo & cables) vs. Akra slip-on. Stock with cables & servo was 15.0 lbs and Akra was 4.6 lbs.
  5. #95
    apriliaforum Junkie skeelo221's Avatar
    Jul 2011
    San Diego, CA
    Nice!
  6. #96
    Roma, Caput Mundi
    some exhaust sound-checks:
    Akra slash-cut:
    SC-Project oval racing and an R1 Akra:
    www.gabroracingteam.it
    Visit my FB page and like it!
  7. #97
    apriliaforum prov-nov Tzvier's Avatar
    Nov 2017
    Los Angeles
    Forgive my ignorance, but why does the guy keep giving it small revs after the pull?
  8. #98
    Roma, Caput Mundi
    I am the guy
    test procedure in my dyno involve a clutch pulled coast-down after the pull to measure lost drivertrain power... so when you reache rev limiter you shut the throttle and pull the clutch, letting the motor idle. those little revs are needed to spin oil and water pumps and have fluids circulate to dissipate the big heat from the pull.
  9. #99
    Nov 2017
    Los Angeles
    Oops, my bad
    Much appreciated for the detailed explanation.
  10. #100
    Oct 2013
    San Diego, CA
    I am the guy
    I had wondered that as well, thanks for the explanation!
  11. #101
    Aug 2007
    San Antonio
    Can a full akra system from a pre RR/RF bike work on the 17s and 16s?
  1. Updated pics of the bike, gianelli exhaust. and garage door opener (56k, you can try)
    By mysubaruimp in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 08-08-2004, 08:49 PM
  2. Exhaust and carbon
    By Pock in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 08-21-2003, 07:46 AM
  3. i need a gasket for my exhaust and power valve
    By sortofsilver in forum RS125 Euro-archive
    Last Post: 06-01-2003, 04:20 PM
  4. idle, oily exhaust and front light
    By Vespa Guest in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 05-29-2003, 12:44 PM
