Results 1 to 4 of 4
Thread: [Electrical] Smoke coming out of stator when attaching a battery
    Apr 2017
    Israel
    Question [Electrical] Smoke coming out of stator when attaching a battery
    Hello, first post here so please excuse n00bness.
    I own a Piaggio Typhoon 50cc 2T AC, Hi-per2 motor and other bits just like Fly 50.
    Couple of days ago I noticed weak lights, no horn, no starter turning and no charging of the battery - voltage was 10V either with motor running or not.
    Took battery home and re-charged it full. While the battery was out, the scooter started fine with kick-start, but lights where again dim as if lower than 12v voltage is supplied by the generator
    When I re attached the fully charged battery back, I quickly noticed thin smoke coming out of the generator/stator cover area. I immediately disconnected the negative pole and this stopped.
    Does this mean I have a short in my stator ?
    Or could this mean the rectifier is bad ?
    Shouldn't the rectifier diodes block battery current from reaching the stator charging coil ?
    Thanks for any advice here.
    ontario
    i suggest a manual to check the rectifier first. the stator sounds dead but it could be the rectifiers fault.
    good luck with the battle. im sorry thats all i can say without a manual. i mean that because your doing a fine job so far.
    can you find the parts ok? how much for a stator and a rectifier?
    Apr 2017
    Israel
    Stator is pretty cheap http://www.ebay.com/itm/261332526489
    However I am having hard time removing the cover, as I don't have the right extractor. Will have to bodge something or buy one.
    ontario
    that is cheap! i think you better get the rectifier and the stator as a suggestion. there was a guy who posted a thread on issues like that. it was about a year ago right here. but i looked and i cant find it now.
    i know for sure if the rectifier is bad it will blow a new stator everytime.
    it sounds like maybe a rectifier problem. when the stators get old and ground out they can be replaced fine but this smoking sounds much worse than that / so a rectifier is recommended as a suggestion.
    i dont have that model so just use your best judgement. your doing good so far
  1. Stinky white smoke coming out of exhaust 2016 factory
    By mtb_prodigy in forum 2012-2017 Tuono V4 - All Variants
    Last Post: 11-01-2016, 03:26 AM
  2. Coverage of stator wires when coming out of the block, has it changed ?
    By steelman_2 in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 03-11-2016, 09:27 AM
  3. Loss of power and electrical smoke coming from under the seat
    By Bart Kolosowski in forum ETV1000 CapoNord (2001-2007)
    Last Post: 05-23-2012, 06:16 AM
  4. Strange grey goo coming out of stator cover plug
    By Tee-Dub in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 07-16-2007, 11:32 PM
  5. Strange grey goo coming out of stator cover plug
    By Tee-Dub in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 07-07-2007, 08:45 PM
