Results 1 to 5 of 5
Thread: What Oil for Scarabeo 50?
    Mar 2017
    Palo Alto
    Also, is there a link for an online manual?
    ontario
    synthetic red oil.
    whats the manual for? tune ups?
    -derbi bullet 2006 - piaggio AC - malossi torque driver half - custom GPS dash - TPR 70CC - topperf crank - vl13 reed and spacer- yamaha rt180 kickstand - giannelli shotV4 - phbg 21mm - doppler mesh top venturi filter - TTO tempurature gauge
    -1992 lt250r suzuki quadracer
    Jenison, Michigan
    Ahhh, the great oil debate...
    If you use the search function at the top of the screen, you'll find plenty of threads with peoples opinions on what oil to use. It's all a personal preference. Just like sublunacy said, use synthetic injector oil. Not all injector oil is red. I use Castrol TTS and it's blue. Just make sure it's not for outboard (boat) engines and it specifically says injector oil for 2 stroke motorcycles. Not premix only, it'll only cause problems.
    2009 SR 50 Factory
    Malossi 70cc BBK
    Malossi HPC Crankshaft
    Stage6 Waterpump Impeller
    Arrow Extreme Pipe
    Malossi VL 13
    Ecu De-restricted 2.8.0
    7 Gram Dr. Pulley Sliders
    Stage6 Soft Contra Spring
    Water Trap
    RS 24/10
    Stage6 260mm Front Brake
    Stage6 R/T Clutch Bell 460g
    Malossi Special Belt
    Malossi E5 Air Filter
    Fuelab 535 FPR
    Glowshift Dual Needle Gauge
    Stock Gears Installed
    ontario
    thats what colours are for - simplification. the red oil mixes better wich is important with auto injectors. on deceleration the oil/fuel ratio is screwy - to much oil and not much fuel.
    the thing the oil is supposed to do - is never mentioned in anybodies threads.
    the temp the oil burns away at and how much is left behind. pointless to discuss with anyone because they see only one side or nobody wins. stick to the colours unless your a hotroder aircooled bike wich needs the green oil but the injector remains a problem....
    red- injectors and liquid cooled.
    green- aircooled and premix.
    green injector oil is perfect for aircooled/oil injected engines running hard. driven normal - the red.
    Jenison, Michigan
    Agip City 2t injector oil (which is now Eni iRide) is the recommended oil for all oil injected Aprilia 2 strokes. It's expensive and the only place I could find it is AF1. It's a gold color.
    https://www.af1racing.com/store/Scri...dProduct=61242
    2009 SR 50 Factory
    Malossi 70cc BBK
    Arrow Extreme Pipe
    Malossi VL 13
    Water Trap
    RS 24/10
    Fuelab 535 FPR
  1. What oil for our 50cc 2 stroke motors?
    By wickedAprilia in forum RS50 Technical
    Last Post: 09-10-2014, 09:59 AM
  2. What oil for Scarabeo 200
    By ispud in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 04-30-2009, 10:32 AM
  3. alarm system for scarabeo 50 (gorilla)
    By Nolegs in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 08-21-2003, 12:54 AM
  4. Exhaust for Scarabeo 50 DiTech.
    By mikesend in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 07-08-2003, 01:45 PM
  5. A review for Scarabeo 50 Ditech...
    By RetroSmokey in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 04-26-2003, 10:13 AM
