Results 1 to 2 of 2
Thread: Odometer reading lost?
    Mar 2017
    Santa Fe NM
    When I swapped out the battery in this here 2009 SR50, I can't find any odometer reading for the lifetime of the bike.
    Surely you don't lose the knowledge of the bike's overall mileage when you simply swap out a battery?!?!?! This happens all the time with motorsports vehicles.
    Zombie bikes with unknown mileage?
    Jenison, Michigan
    Lucky you! You just magically earned "brand new" 0 miles status! That is weird though, I had to buy a used cluster and who knows how long it was disconnected from the whole bike. Should be right there...
    2009 SR 50 Factory
    Malossi 70cc BBK
    Malossi HPC Crankshaft
    Stage6 Waterpump Impeller
    Arrow Extreme Pipe
    Malossi VL 13
    Ecu De-restricted 2.8.0
    7 Gram Dr. Pulley Sliders
    Stage6 Soft Contra Spring
    Water Trap
    RS 24/10
    Stage6 260mm Front Brake
    Stage6 R/T Clutch Bell 460g
    Malossi Special Belt
    Malossi E5 Air Filter
    Fuelab 535 FPR
    Glowshift Dual Needle Gauge
    Stock Gears Installed
  1. Odometer reading vs GPS
    By rdbandkab in forum 2014-2017 Caponord 1200
    Last Post: 09-26-2015, 08:11 PM
  2. Odometer reading comes from where?
    By Mac of Duart in forum ETV1000 CapoNord (2001-2007)
    Last Post: 03-17-2009, 05:09 PM
  3. Important Question about milage and the odometer reading.
    By Kuneff in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 08-03-2008, 11:21 AM
  4. Odometer reading
    By Peggy in forum RS125 Euro-archive
    Last Post: 09-18-2006, 12:53 PM
  5. odometer reading zero
    By rsvrtosh in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 01-23-2004, 04:19 PM
