Results 31 to 45 of 66
Thread: 85mm stroke crank, need help
  1. #31
    Jan 2005
    Finland
    Wide open and then gave it a phew kick start too. Didnt rise from that 90 psi. Ill take some pictures whden i remove the head so you can see where the piston sit ats top position.
    Aprilia SR 50 R Factory 2009 Silver Crowd
    Aprilia SR 50 2008 Silver Crowd
    Aprilia RS 50 2003 SBK Replica
  2. #32
    ontario
    do you have a reed valve spacer to lower the primary compression?
    perhaps removing the base gasket in favour of case sealant will bring the secondary compression up.
    perhaps a cylinder like a trophy 70cc and reed spacer or two.
  3. #33
    Jan 2005
    Finland
    Maybe the best way would be take off some material from the spacer that sits between block and cylinder.
    Reed valve assembly and intake are all oem stock.
  4. #34
    ontario
    did it run before you took it apart? can you check for spark again?
  5. #35
    Jan 2005
    Finland
    Here are the pictures. Hope they tell something. For my eye the piston does not sit too low. its a brand new piston, only spinned when tried to start this thing. OEM head with oem gasket. oem cylinder with 10 000km on it.
    It has not run since my 70cc blew up and took it apart to install these orginal parts to get it fixed.
  6. #36
    ontario
    that looks good.
    it looks real good. it seems removing the base gasket will take it to far and hit the head.
    it looks like a longer stroke crank? the piston at the bottom looks lower than normal- the top dead center looks great thou.....
    i guess it is stroked 2.5mm and a 5mm longer rod. the cylinder looks fine where it sits.
    ~ what about the reed valve????????
  7. #37
    ontario
    is it still apart?? i can help you port that cylinder and bring it up to sport class output?
  8. #38
    Jan 2005
    Finland
    Stroke should be the same. Only shaft should be longer. With the spacer it should be normal situation.
    I do not want to touch this cylinder. Only make it run again.
    As far as i have checked the reeds. They work fine. Oem factory part.
  9. #39
    37 miles E. of ATX, TX USA.
    I am truly hoping you mean 85mm rod because 85mm stroke is about right for a 500cc single?
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
  10. #40
    Jan 2005
    Finland
    What do you think? even tho I have made the same mistake before. Must be somekind of a lost in translation for me.
    I really am running out of ideas. I guess I could do a spark video. If that seems ok. Well all I can do is to take the engine out and assembly with oem crank.
  11. #41
    Jan 2005
    Finland
    so here is the spark video. mobile quality, sorry for that. Cylinder head is off on this video.
  12. #42
    ontario
    Quote Originally Posted by Ärräksä View Post
    it looks very dry. if you dont want to try dumping fuel down its throat again / then i guess your out of options.
  13. #43
    Jan 2005
    Finland
    It seems that this is a total mystery. No one has a clue and Ive asked around plenty.
    Only thing I can think now is to assembly it with the stock crank. Makes no sense why that would help but I have no other means on this machine.
  14. #44
    ontario
    i would be happy if you throw the head back on and try to start it again. no need to fill the coolant/ or overtighten the nuts.
    -- i picture a spray bottle filled with fuel and the gas tank unhooked / dissconnected. then spray the carb inlet.
    im 8000 miles away so its just a suggestion. it would take less than 20 minutes to try again.
  15. #45
    Jan 2005
    Finland
    Or would a starting fluid be even better? If I took off the carb and reedvalve and spray it straight to cylinder? If that shit doesnt ignite it well nothing does.
  1. Do long stroke cranks need case work am6
    By Sketchytom in forum RS50 Technical
    Last Post: 09-04-2015, 11:33 PM
  2. Need help.. 2 stroke 50cc scooter
    By windy in forum General Motorcycle Talk
    Last Post: 01-31-2014, 12:21 PM
  3. relay,starter, or ?, need HELP!!!! Wont crank!
    By dragon in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 03-09-2012, 10:08 PM
  4. Need help bad...Tuono won't crank
    Last Post: 06-29-2010, 09:24 AM
  5. crank instakation, need help!
    By josho44 in forum RS50 Technical
    Last Post: 05-19-2003, 07:08 PM
