Results 16 to 30 of 66
Thread: 85mm stroke crank, need help
    Jenison, Michigan
    Hook some jumper cables up to it or you can start it with a drill from the ignition side (rotating clockwise). I rebuilt the top and bottom end of my YZ 125 and used a lot of oil putting it back together. I fouled 7 spark plugs and ended up having to pull start it with a car (doesn't work with a scooter) and it started first kick every time after that.
    2009 SR 50 Factory
    Malossi 70cc BBK
    Malossi HPC Crankshaft
    Stage6 Waterpump Impeller
    Arrow Extreme Pipe
    Malossi VL 13
    Ecu De-restricted 2.8.0
    7 Gram Dr. Pulley Sliders
    Stage6 Soft Contra Spring
    Water Trap
    RS 24/10
    Stage6 260mm Front Brake
    Stage6 R/T Clutch Bell 460g
    Malossi Special Belt
    Malossi E5 Air Filter
    Fuelab 535 FPR
    Glowshift Dual Needle Gauge
    Stock Gears Installed
    Jan 2005
    Finland
    Everything is stock now exept the pipe is leo vince touring cos the oem pipe didnt fit anymore.
    I allready had a airsal 70cc sport setup and it didnt last. Not going there anymore.
    Aprilia SR 50 R Factory 2009 Silver Crowd
    Aprilia SR 50 2008 Silver Crowd
    Aprilia RS 50 2003 SBK Replica
    Jan 2005
    Finland
    Quote Originally Posted by 2Strokesforlife View Post
    A booster could work. I remember seeing videos of geared bikes drilled from magneto but scooters from varioside. Guess it doesnt matter which side. Alltho my magneto side cover is busted and pain in the butt to close so im going to vario.
    Jan 2005
    Finland
    Drillling didnt work. Odd is i didnt smell strong gas after quite a bit of cranking. Imo it should get fuel coz line to carb works. I also injected straight thro carb yesterday but didnt work.
    Jan 2005
    Finland
    Cleaned carb. Checked lines. Checked reeds. Changed cdi. Took off cylinder head. Poor gas thru sparkplug hole. Result: Nothing. It wont even try.
    Guess ill buy a new stator next.
    ontario
    compression-spark-fuel
    testing the stator is simple. just test it first.
    ~ have you tried holding your hand over the carb air inlet while starting it? if that works you can fix it atleast.
    ~ i would also want to know if the float bowl is empty or not.
    ~if the spark is blue then you have spark problems.
    Jan 2005
    Finland
    Last time my stator died on me i tried all advice i could find to measure it. Everything suggested it was fine. Well it wasnt so im gona save me from that hazzle and just buy a new one.
    I have tried hand trick on the carb. It only changes noise. So does opening throttle.
    There is fuel in the carb also.
    All i do know is i do not trust a spark. Seeing it doesnt make it good enough. Strange is that the motor doesnt even promise anything when i put gas thru spark plug hole.
    Makes me wonder if it has something to do with the adapter. But it should not affect timing right?
    ontario
    if your getting a thin blue spark it might not start. it should be white/yellow/orange kernel.
    hope that helps.
    Jan 2005
    Finland
    We will see. I ordered new stator and battery + other bits and pieces.
    Edit:
    scooter-attack just emailed me that my compression tester is in backorder from the manufacturer. Hope it arrives sooner than later.
    Anyway:
    What would be a healthy compression for a SR 50 R?
    Jan 2005
    Finland
    Hey guys!
    Whats a healthy compression reading? 8-9 bars?
    ontario
    yes sure
    Jan 2005
    Finland
    Well this cant be right... i changed the battery for a new one, completely charged. Before i was going to measure the compression I decided to give it a last go with a new battery to see if it starts but no.... it does not have thd power to crank the motor. It only tries and makes a terrible noise. I thought it happens cos my old battery was dieing but now i realize that something is horrible wrong assembled. I mean it makes sense now that the kick start was so hard to kick and even the drill felt kind of resistant.
    Fudge. Ill have to first disassemble the variator and see whats going on. I mean what else could make it so thatt it feels like the whole engine is stuck?
    ontario
    if the crankshaft bearing fit is to tight it will cause alot of friction/ its plain and simple answer. it wasnt in a book anywhere.... when the clearance is very tight on the shaft and case- the ball bearings get stiff. in other words one tight fit might be ok but two tight fits and there is no where to go. maybe it will loosen up or fail premature.
    Jan 2005
    Finland
    Finally arrived at my garage. Measured the compression:
    90 PSI
    its like 6 bar? Too low right?
    ontario
    yes. like a thin metal base gasket deleted or something. are you positive it was wide open throttle during the test?
  1. Do long stroke cranks need case work am6
    By Sketchytom in forum RS50 Technical
    Last Post: 09-04-2015, 11:33 PM
  2. Need help.. 2 stroke 50cc scooter
    By windy in forum General Motorcycle Talk
    Last Post: 01-31-2014, 12:21 PM
  3. relay,starter, or ?, need HELP!!!! Wont crank!
    By dragon in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 03-09-2012, 10:08 PM
  4. Need help bad...Tuono won't crank
    Last Post: 06-29-2010, 09:24 AM
  5. crank instakation, need help!
    By josho44 in forum RS50 Technical
    Last Post: 05-19-2003, 07:08 PM
