Page 5 of 5 FirstFirst ... 345
Results 61 to 63 of 63
Thread: 85mm stroke crank, need help
  1. #61
    ontario
    i think the needle is rich. perhaps a 64 or 66 is more like it.
    --- diploma for engine repair in 2012 --- powder coat painting --- porting and polishing/ceramic ---
    --- custom parts and machining ---
    -derbi bullet 2006 - piaggio AC - malossi torque driver half - custom GPS dash - TPR 70CC - topperf crank - vl13 reed and spacer- yamaha rt180 kickstand - giannelli shotV4 - phbg 21mm - doppler mesh top venturi filter - TTO temp gauge
    -1992 lt250r suzuki quadracer - new and improved
  2. #62
    ontario
    yes i think the needle is rich one notch to much.
    the main jet is maybe 64-66 with the lv touring pipe. or 58/60/62 with the stock pipe. as a guess!
    jixaw is using that lv touring pipe on a 70cc morini and a 15mm carb and he loves it very much for city driving. everything else is stock!
    the airsal 70cc sport kit uses the stock head for lower compression and it runs smoother becauase it is not a squish head design. it is very cheap. get that and finish the bike like the factory intended - 70cc and torque pipe with a 1000rpm overrev ---
  3. #63
    Dec 2015
    Cambridge, MA
    i do mostly city driving and a malossi 70 + Leo Vince Touring + 15.15 SHA work great for getting from traffic light to traffic light
    2004 Aprilia Mojito Retro 50cc
    2003 Vespa ET2 50cc
    2001 Triumph TT600
  1. Do long stroke cranks need case work am6
    By Sketchytom in forum RS50 Technical
    Last Post: 09-04-2015, 11:33 PM
  2. Need help.. 2 stroke 50cc scooter
    By windy in forum General Motorcycle Talk
    Last Post: 01-31-2014, 12:21 PM
  3. relay,starter, or ?, need HELP!!!! Wont crank!
    By dragon in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 03-09-2012, 10:08 PM
  4. Need help bad...Tuono won't crank
    Last Post: 06-29-2010, 09:24 AM
  5. crank instakation, need help!
    By josho44 in forum RS50 Technical
    Last Post: 05-19-2003, 07:08 PM
