Results 1 to 5 of 5
Thread: Fork Bushings discontinued?
    Sep 2012
    washington
    Was talking to an Aprilia dealer and they tell me you can no longer buy the fork bushings for the 09 Dorso-you can only buy the complete fork.
    Does that sound correct??
    Had to replace the seals because of a leak on the left side. Held for about 2000 miles, then started weeping again. Fork alignment is good. Replacing the seals for the second time(with SKF) and figured I might as well do the bushings while I am in there.
    Jul 2007
    Kapiti, New Zealand
    I hope not, but I doubt it. Parts are generally supplied for 10 years after a model is discontinued (e.g. the commitment by Victory motorcycles).
    Have you checked online on the AF1 site?
    Frodo
    2015 Shiver
    New Zealand
    Sep 2012
    washington
    Yes 10 years is pretty standard. Guess I will check AF1 and see what I find.
    Feb 2017
    Hanoi, Vietnam
    How did this end up? did you get them?
    Feb 2012
    Sierra Nevadas
    If they are not available from Aprilia, AF1 or Aprilia UK may still have some in stock.
    If not, I'm sure there are other manufacturers that have the same size part that will work. All Balls makes the seals, as well as wheel bearings. I don't see the bushings, though.
  1. Fork bushing
    By JohnG. in forum ETV1000 CapoNord (2001-2007)
    Last Post: 09-11-2012, 01:06 AM
  2. Fork bushings problem
    By Babelfish in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 04-16-2012, 02:00 AM
  3. Remove fork bushings (Öhlins) ?
    By GreaseSnake in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 09-04-2010, 03:14 AM
  4. ohlins fork bushing question
    By fast4d in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 04-06-2010, 11:39 AM
  5. Replacement of Front fork bushes (Rally 50)
    By Clumpsdad in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 06-29-2006, 01:21 AM
