Results 1 to 5 of 5
Thread: sr50r 2015. Need help. find part number. front top panel.
    Feb 2017
    sydney
    my scooter missing the front top panel.
    i want to buy a new one or a used one.
    where can i find one?
    where can i look for oem number or part number?
    thank you in advance.
    here picture attached.
    apriliaforum Junkie 2Strokesforlife's Avatar
    Aug 2016
    Jenison, Michigan
    Hi there! Part# AP8268059. There's two other part numbers for the same black panel but if you google this one, they'll all pop up on any Aprilia parts website. Maybe keep an eye out on Ebay for a used one. It isn't cheap.
    2009 SR 50 Factory
    Malossi 70cc BBK
    Malossi HPC Crankshaft
    Stage6 Waterpump Impeller
    Arrow Extreme Pipe
    Malossi VL 13
    Ecu De-restricted 2.8.0
    7 Gram Dr. Pulley Sliders
    Stage6 Soft Contra Spring
    Water Trap
    RS 24/10
    Stage6 260mm Front Brake
    Stage6 Torque Control MKII 107mm
    Stage6 R/T Clutch Bell 460g
    Malossi Special Belt
    Malossi E5 Air Filter
    Fuelab 535 FPR
    Glowshift Dual Needle Gauge
    Stock Gears Installed
    Feb 2017
    sydney
    thank you. 2Strokesforlife
    Nov 2004
    sheboygan,wi USA
    I have a panel for sale if you need it? If your in the states it is 40 shipped
    Sent from my iPhone using Tapatalk
    matt davis
    Nov 2004
    sheboygan,wi USA
    I have tons of parts for the Sr50 eBay is to expensive and I not looking to make a ton of money either just need stuff gone
    matt davis
  1. sr50r 2015. Need help. wire connect t to engine. next to coolent pipe.
    By apple88 in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 02-25-2017, 09:08 AM
  2. Replies: 3
    Last Post: 05-07-2016, 04:36 PM
  3. need help finding parts
    By keeks in forum 2006+ Pegaso Trail / Strada / Factory
    Last Post: 07-07-2013, 06:46 AM
  4. need help with part number!
    By Andrew_ in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 04-29-2009, 10:28 AM
  5. Hey lads, I need help finding parts to restore the RSV after the Linkage broke
    By scott2ride in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 11-14-2008, 05:02 AM
