Results 31 to 45 of 58
Thread: How do I get more power?
  1. #31
    ontario
    the next r is a very very good pipe. the clutch dumps will pull harder than all most any other pipe.
    as for cylinders - there is only 3 cylinders worth buying i think. the tp trophy 70. the airsal sport 70. s6 streetrace 70 has quality control problems.
  2. #32
    Jan 2017
    North Lincolnshire, Humberside
    Will the airsal sport work well?
  3. #33
    ontario
    thats a good question. a very good question and this is my answer.
    the airsal will be better with a variator because it will think the pipe is a little short. so it will have good clutch dump but the power will take a little longer to reach peak power.
    the trophy or streetrace have high exhaust port heights with no other changes at all. this has a slight drop in power at the clutch dump but the pipe will reach peak power about 600rpm earlier because because the pipe will act longer than it is. this should get YOU 8200rpm of peak hp. that is good for your variator.
  4. #34
    ontario
    soo it looks like the tp trophy and a clutch will do it! i guess that worked out ok for you. tp has a clutch too but i dont know the engage rpm. i think it is a stock replacemennt 2000rpm clutch but i really dont know.. motoforce has a cheap clutch aswell but again i dont know the rpms.....all the others seem to be racing clutches and there is no option to tune them to 5000rpm / they take care of the crowd that need the 6000-8000rpm clutch dumps.
    either way post a video of it hauling ass please and find a 10 peice mainjet kit so you can jet it. done
  5. #35
    Jenison, Michigan
    That's weird, I rode my bike for a whole summer with the yellow Malossi clutch springs, stock clutch, stock clutch bell, stock belt, stock variator, 5 gram rollers, had a 6,000 RPM engagement point and I could cruise all day at 50 MPH with no slipping.
    2009 SR 50 Factory
    Malossi 70cc BBK
    Malossi HPC Crankshaft
    Stage6 Waterpump Impeller
    Arrow Extreme Pipe
    Malossi VL 13
    Ecu De-restricted 2.8.0
    7 Gram Dr. Pulley Sliders
    Stage6 Soft Contra Spring
    Water Trap
    RS 24/10
    Stage6 260mm Front Brake
    Stage6 R/T Clutch Bell 460g
    Malossi Special Belt
    Malossi E5 Air Filter
    Fuelab 535 FPR
    Glowshift Dual Needle Gauge
    Stock Gears Installed
  6. #36
    Jan 2017
    What do you mean with a variator? You said to buy the airsal sport, box of jets, springs and 5g rollers?
  7. #37
    ontario
    [QUOTE=2Strokesforlife;4211133]That's weird, I rode my bike for a whole summer with the yellow Malossi clutch springs, stock clutch, stock clutch bell, stock belt, stock variator, 5 gram rollers, had a 6,000 RPM engagement point and I could cruise all day at 50 MPH with no slipping.[/QUOTE/]
    well its not weird to have respect for your machine. i would not want to cruise in slow traffic with clutch springs. if you could give complete pros and cons then i think you have a sound arguement. but just labeling springs as no problem is contidictory to getting help in the first place.
    I LIKE HAVING YOUR 2ND OPINION - this sounds like im picking on you....
  8. #38
    ontario
    Quote Originally Posted by JakeMan1 View Post
    no not the airsal. not with that pipe.
    trophy 70 or a s6 streetrace 70. you need clutch springs or a malossi fly clutch. also need jets for the carb.
    done.
  9. #39
    Jan 2017
    But you said before it would all work with my pipe I have now
  10. #40
    ontario
    i guess i did say that but i take it back to simplify. you should read some bbk installs and when you feel confident go for it.
    their are people here to back u up when you need it.
    snipez and 2strokesforlife and jog plus some up and comers will help / but your responsible to see it thru. we cant come over a try try a bunch of stuff....
  11. #41
    Jan 2017
    Yeah just don't have huge amount of funds to spend
  12. #42
    ontario
    grab some springs then and wait till summer for the 70cc. are you in school? dont mix scooter tuning with school. you likely to fail at one or both lol
  13. #43
    Jan 2017
    Yeah I Am haha
  14. #44
    Jenison, Michigan
    That was the 50cc setup, before I crashed and wrecked my knee (the turn lane was full of sand and gravel). Clutch springs, a de-restricted pipe, and rollers made it a fun and pretty quick bike for a 50. A little jumpy with the yellow springs when riding in the city, which is why I suggested the white (one step softer). At 70cc, a new clutch, heavier rollers, better belt, reeds, and crankshaft were needed. Among the other little things that suck money out of your pocket. I've done my fair share of experimenting with different transmission setups (rollers, clutch springs, variator adjustment washers) and then there are the things that are DiTech related. Some worked, some didn't. And don't worry, no offense taken, I may still be a little new to the forum, but I've been working of stuff like this since I was 15 back in '95. Damn, that makes me feel old...Lol!
    2009 SR 50 Factory
    Malossi 70cc BBK
    Arrow Extreme Pipe
    Malossi VL 13
    Water Trap
    RS 24/10
    Fuelab 535 FPR
  15. #45
    Jan 2017
    I don't have a ditech though, I'm not looking to spend loads of time building it and spending loads on it because come September when I'm 17 and I'll be getting a car and taking my car test and hopefully getting a 125! But for the next 8 months a really want to enjoy my 50 without spending a bomb to make it enjoyable, I just thought I could throw a 70 kit straight on it a couple months ago until I got told I would need a new crank and I gave up with the idea because of without funds!
  1. how to get more power from the rs 125
    By recessionracing in forum 2009 RS125-USA
    Last Post: 07-18-2014, 01:14 PM
  2. How do I get full power from a 78 KW Tuono?
    By Twinpipes in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 08-09-2011, 11:05 AM
  3. how to get more power?
    By 03v60 in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 05-11-2009, 01:33 PM
  4. how do you get a good clutch start from 0mph at lights
    By memphisrs50 in forum RS50 Technical
    Last Post: 06-19-2003, 02:58 PM
  5. How do I get to see newer posts?
    By jlb43 in forum Aprilia and Piaggio 500cc
    Last Post: 11-13-2002, 02:26 AM
